Severe hesitation on acceleration. Need Help!!!
Old 08-17-2005, 01:51 PM
  #41
aleveran's Avatar
Originally Posted by THEJEFFERATOR
although the engine runs on alt. power after start-up, there is extra load placed on the alt. when trying to re-charge an extremely weak battery. if the total load requirement exceeds the maximum output allowed by the regulator, something may be cheated of the neccesary voltage ? much like when trying to jumpstart another car, load increases, the idle drops and sometimes takes a while to start it cause the alt is limited to its output ? i don't know if any of this makes sense, im just tryin to convince myself !!!!
Do this test then: When 'idle' turn on high load electrical components (head lights on hi b, fan on 4, stereo on full, move all 4 power windows simultaneously, brake lights, horn) and if your engine still runs then there is enough battery power.
aleveran is offline
Old 08-19-2005, 11:49 AM
  #42
tolken4's Avatar
You are brilliant!!!
I have the same issues. Rough idle, strumbles untill about 3 grand. HERE IS THE GOOD PART!!!
My alternator has been jacked up for about a year and a half. Just enough to charge the battery at highway speed. If I go to a couple of short trips in a row my battery will not have enough juice to start the car... If I sit in park with ac and accessories on, it will not start again. YOU GET THE POINT.
So, I am betting this is a spark issue directly contributable to the alternator. I am getting a new alternator tonight and will update the board when I am done putting it in.
Oh, one more thing... I had taken the car to the dealer, they could not work on it, but it was really, really, dead when I got it back. Had to jump it and the kid at the dealer could not even get it to stay started. Ended up starting it for them and keeping it pegged at 4,000 all the way home. Anyway it was running worse then than it ever had. I bet it was the juice being dead.
Take care, and thanks for the theory. BRILLIANT!!!
tolken4 is offline
Old 09-06-2005, 11:20 AM
  #43
aleveran's Avatar
Originally Posted by aleveran
No luck. Wires seem ok.
01 01 - Camshaft Position Sensor
04 07 - Crankshaft Position Sensor (reference)
Can't get rid of them. Hesitation and stalling persist.
Could it be MAF sensor dieing slowly without showing any ECU codes???
aleveran is offline
Old 09-06-2005, 11:53 AM
  #44
THEJEFFERATOR's Avatar
thats gonna be my next step, changing the maf ???
hesitation and stalling pissin me off !!!
THEJEFFERATOR is offline
Old 09-06-2005, 12:03 PM
  #45
aleveran's Avatar
another $200
aleveran is offline
Old 09-06-2005, 12:04 PM
  #46
oh yeah, JeEve told me in another post he was havin probs with those sensors and it was a ground problem. a wire off the main harness was bad. maybe check that...
Old 09-06-2005, 12:15 PM
  #47
aleveran's Avatar
I used jumper cable once and re-grounded the engine in every possible place...it did not help....
aleveran is offline
Old 09-06-2005, 06:18 PM
  #48
nismology's Avatar
Try replacing the fuel filter. I find it unbelievable that you would change the fuel pump and FPR before replacing the fuel filter. Unless im mistaken and you already replaced it, this is kinda 'ed
nismology is offline
Old 09-06-2005, 06:28 PM
  #49
nismology's Avatar
Originally Posted by njmaxseltd
The Camshaft Position sensor controls the sequential fuel injection timing.
Crankshaft Position (REF) controls ignition timing.
Crankshaft Position (POS) reads top dead center on every piston and will cause a no start condition if it fails.
That's incorrect. All three sensors are used for both the fuel injection and ignition systems.
Old 09-07-2005, 04:14 PM
  #50
aleveran's Avatar
Can MAF sensor die slowly without showing any ECU codes ?
aleveran is offline
James92SE
142
01-02-2024 09:23 AM
ef9
10-04-2015 08:43 AM
JoshG
51
09-21-2015 10:41 PM
jchronis2552
09-21-2015 05:52 AM
trungg86
09-04-2015 04:58 AM
Quick Reply: Severe hesitation on acceleration. Need Help!!!
