Help brake light on.
Basically about 2 days ago the brake light came on then went off, didnt stress it. I thought it was the emergency brake acting up cause light would be on when i didnt have it down 100%. Now light came on and wont go off. Car has brake fluid, and when i took the center councel apart i was able to push in the lil sensor for the emergancy brake and light stayed on, so i dont think thats it either. Checked codes and nothing... any ideas? anyone have similiar prob, if so what sollution? Please don't say "take it to shop", i went took automotive classes, bro is ASE certified, and best friend head tech at porsche... just want to know any recomendations b4 i start tearing the brake system apart.
thanks
-carlos
aim croman814
thanks
-carlos
aim croman814
Originally Posted by g4nismo
so ur brake lights constantly stays on or whenever u turn ur car on?
Also new brakes less then 6 months ago new brembo slotted and drilled up front with cut stillen slotted rears and all new pads (bought organic somehow, but doubt thats prob). One used rear caliper one new/rebuilt. keep comments comming!
btw... i do need to have drivrs side front wheel bearing replaced, just havent had time. Don't think thats related but never know.
Take out your center console and inspect the ebrake sensor contact, you may need to adjust it. I'm not sure on adjusting it, but I came across it in my Haynes manual once. Just make sure that the two metal peices are not together all the time, only when ebrake is engaged. This will make more sense when you have it apart, pretty basic switch design.
all this lil crap makes me wanna just upgrade to newer car again... no time for bs stuff, cars great but fixing lil crap get annoying and i work too much to be messing with car.
Originally Posted by Mr.Duck
your e-brake could have seized up?
thanks everyone for all the hepl, my original guess was in fact right. Went thru system today with some light, took off sensor/conetor to pin on emergency brake and light went out. After cleaning and replacing it works fine now. Also adjusted e-brake, theres a 12 bolt under e-brake boot that u can tighten to adjus. Everything seems good now, just need todo wheel bearing now.
tsi6001
10-03-2022 10:23 PM
JMag90
08-25-2015 09:17 AM
