Engine Code 0307
It is a closed loop control. Any clues to what that means? It also came with engine codes 0304 and 0608. My car is a '95 GXE auto with 85.5K on the odometer. The only mods is a Stillen intake. i do have a stereo system. any advice is greatly appreciated. oh, some symptoms are that it idles at 500 to 600 rpms and shakes bad, has smoke comming out of the exhaust pretty badly at times, and i've averaged between 8.5 to 5 miles to the gallon. recent repairs have been a new starter and new fuel injector. i have been using 87 ghetto gas for awhile and switched to chevron 89 about a 6 weeks ago and just switched to chevron 92 two weeks ago. i just filled it up with 92 and used a fuel injection cleaner. thanks.
DTC 0307
DTC 0307 is detected when the closed loop control function for the left bank does not operate even when the vehicle conditions meet the criteria (engine at normal operating temperature, etc.). Possible causes include ...
- Harness or connectors (The sensor circuit is open or shorted.)
- a defective Front Heated Oxygen Sensor sensing element.
- a defective Front Heated Oxygen Sensor heater.
i had brought my car to my father's while i was out of town and he had it checked out on the computer and then replaced the fuel injector. the check engine light went out right after that and hasn't come on until now. i assumed that the fuel injector was at fault and since i had it replaced, it'll be all good. i checked all the plugs this morning and they are all fine. oh, and the codes 0304 0608 are the same, but i also had 0201 at the time but that is now gone and 00307 replaces it. could i be getting these codes due to a faulty factor O2 sensor like some people on the board have posted?
derekinthez
11-13-2022 04:00 PM
