Need a lil help with this "antena" mod
Ok, let me start off by sayin i hate the look of a max with its antenna up, it looks like an RC car .... SO, i was sittin in class today and startin thinkin.. what if i put a switch on my antenna power source??? So I tore apart the trunk and found the wires that controlled the power to make it go up and down. The wire connector had a Pink, White, and Black (ground) wire. Now for my question---
--- is it the pink or the white wire that controls the power?
No, I am putting a switch on it so if i ever get bad reception i can just flip the switch and up goes the antenna.
Can you specify where the blue wire is because i dont want to snip a speaker wire or something.
I'm sure it is very possible on the maxima. I did this on my previous car (integra). Like Crockpot said, there should be a wire from the stock headunit harness that provides power to the antenna. Just cut it, and run a switch in between. On my integra, I installed the switch right under the front of the armrest.
Any repair manual (Haynes, Helms, FSM) should have wiring diagrams for the stock radio. Look for the wire that goes to the antenna.
I am looking at the wiring diagram and it says:
Bat (Back up) = pink or pink / blue
Ant Signal = Black/ Red ----> Power Antenna
With that info, does it mean the pink is the power source to the entire head unit?
what exactly would i do to test it with a volt thingy-ma-jig
Question, I'm assuming you're doing this to a stock headunit .. why would you need this? On my old stock system the ant. was already switched... when ever radio turned on it came up...
and if you are running an aftermarket hu just switch the power to the blue wire on the wireharness... so whats the question again ?
On my stock Bose headunit, the antenna already only goes up when the radio is on...
I know, but i ran a lil test and realized when the radio is on and the antena is down, the reception difference is nearly unnoticeable. So that switch will allow me to listen to the radio sithout the RC car look, but if i ever need an antenna, i could put it up in the flip of a switch...
Why not get an antenna like an IS300 or something? Its small, black and mounts to top of the rear window. They even look pretty good too. I to hate the stock antenna on the maxima. I rarely listen to the radio either, Im probably going to disconnect it from the HU.
I would get the IS300 antenna, but only if i could shave the antenna i have now because what is the use of it if it ISNT being used.... get my drift. I also dont have the money to do all that because i am saving for other things (exhaust, I.C.E., etc...), so why not still have the stock antenna functionable only when needed. So far, my reception has been great even with the antenna down, so ima go ahead and do this mod if i have time when i get home from work. shall be fun
Finished the mod!!!!
-- I started out by going behind the dash to look for the wire. I was gonna run the wire from behind the HU so i wouldnt have to use TOO much wiring. Well, it turned out that our good old friends at Nissan wrapped all of the wiring with a what seems like a quarter inch of electrical tape. I said scratch that idea, ill just run the wire from where the harness is in the back.
-- I found out that the power wire that control whether or not the antenna goes up or down is Black/ Red. So, I cut that wire and put a switch on it. I mounted the switch near the fuse panel up by the driver's seat.
--Now, I can have my antenna go up and down at my will....
zzznightmarezz
09-21-2015 06:32 PM
