Replacing Hood Struts
How hard is it to replace the hood struts on a '96? I was going to try some of the after market ones from an auto parts store as mentioned in a few other posts. It appears I have an access space to reach the inside nut on the lower mounting but there is no access hole to reach the inside nut on the top mounting. Anyone ever done this?
The hood struts aren't that hard to take off. At least not on my 98. They do not pop out of the joint like they do on some other cars. That little nut shaped thing at the top and bottom of the strut is how it's held on - just unscrew that with a wrench and out it comes.
Finding the replacement is the hard part. Maybe you'll have better luck with the 96. For me, I could not find one compatible aftermarket strut because of that damned mounting on the top and bottom.
And like hell I was going to pay Nissan $86 dollars a side. For a support strut? I told them and to come on over with their sister and **** my ****!
What I ended up doing was cutting a piece of wood down and creating a support beam outa that. In the '98, there's a great space for it to rest between two fluid tanks on the passenger side (near the front, and I rest it against one of the indents on the inside of the hood. I gave it a good shake to test it, didn't fall.
I would do something like that, or build yourself a metal support rod with a dowel, a hinge, a ball joint socket and some high-durability glue if you wanna get real fancy.
Remember: the hood is not as heavy as you think it is. It doesn't take much to hold it up.
Shayyadin
Shayyadin
Strong Arm #4524
Installation is not difficult. Prop the hood open with a broomstick. Use a 13mm open end wrench to remove the upper (hood) and lower (inner fender) ball studs. The ball studs are permanently mounted to the sockets on each end of the factory lift. After both studs are backed out of their threaded holes, the lift comes off the car (with the ***** still in their sockets). The Strong Arm replacements ball studs are not attached to the replacement lifts. Thread the ball studs into the threaded holes on the hood and inner fender and tighten with a suitable wrench. Then simply "snap" each socket end of the replacement lift on the ball studs. Repeat the process for the other side.
Strong Arm hood lift supports are made in the USA by AVM Inc, part of Arvin Industries. See http://www.avminc.com/strongarm/
Re: Strong Arm #4524
Originally posted by Daniel B. Martin
Go to AutoZone or Advance Auto and ask for Strong Arm #4524. The price is about $16 each, and that's much less than the Nissan factory part
Re: Re: Strong Arm #4524
Question for Daniel Martin - what did you mean by 'threaded bosses' - is that sorta like a nut attached permanently inside the hood channel (I just want to make sure when I take the strut off I don't lose the nut inside the channel)? Thanks, Dave
Threaded holes
Done! I purchased Strong Arm #4524 at Advance Auto (they called their warehouse and they were at the store the next morning at 9am. The price is about $16 each (no shipping) - Nissan dealer quoted $107 each. Very easy to install (about 15 minutes)!
These can also be ordered online from www.partsamerica.com.
Thanks to Daniel Martin and all the others for your help!
Be sure
Check prior posts on this subject from Daniel Martin. He found the part number for the hood lift struts that Advance Auto carries. I bought a pair and put them on a couple of months ago and was very satisfied. They were only about $15 each!
Shayyadin
Shayyadin
I spoke to the customer service department at Strong Arm and they gave me the following information about stores and parts numbers in California:
NAPA Auto Parts: Part # 819-4737
Autozone: Part # 95784 ( Mighty Lift )
Kragen: part # 072-862 ( Steady Lift )
Car Quest: Part # 4524
Originally posted by NUGE
I just purchased the hood struts from partsamerica.com. I ordered the part # 4524, But I just realized that there might be a difference between the right side and left side. Can anaybody tell me if there is a difference.
I got the Strong Arm hood struts from Partsamerica.com..and I couldn't be more pleased with them. They are awesome. We'll see how they hold up over the next year. BTW - they are VERY easy to install. 10 minutes tops
You know my original hood struts lasted for almost 5 years, and then
they wouldn't hold the hood when it was real cold out, then the wouldn't hold the hood at all.
I priced Nissan Hood Struts and thought that they were too damn expensive.
I found Carquest Hood Struts (Part #4524) and the both sides together cost me around 45.00, and I thought I was really smart for finding them cheaper than Nissan's struts.
One year later (instead of five years I got with the originals) the damn struts won't hold the hood up!!!!!!!!!!!!!
White96MaxSE
White96MaxSE
Yay! An 8 month old thread is back up again
Most folks have had good luck with the cheaper alternative. I just got mine last summer from Partsamerica and so far, they work fine. Sorry yours didn't work
White96MaxSE
White96MaxSE
I installed the same #4524 parts about 6 months ago. Don't remember where I bought. Don't remember either how strong the original hood strus were but I think the #4524 is not so strong. I have to lift the hood like 90% then I'm sure the hood will be supported and not fall down. However it is like that fron the day I put it in.
I only remember from online where I ordered, there were three #4524, the first one was cheapest so I ordered the second one that was priced the same as the last one, but wit diiferent brand... I thought "I get what I pay for", and maybe it still holds true, who knows the first, cheapest one will fail even sooner...
Your right about the old thread, but being a newbie I found it and I just thought I would add my experience with the aftermarket hood struts to assist someone else in evaluating what to do about it.
1/5 the price is right, and I guess I'm going to buy another pair and see if they last longer this time because I don't like any of the other alternatives discussed so far.
White96MaxSE
White96MaxSE
Originally posted by kmax97
I just ordered a pair from partsamerica.com and I'll be receiving them next week... they're a real bargain compared to the dealer's prices... but I hope they will last a long time~!
I'm going to put another pair (this time from Midway Auto Supply) on this weekend. Wish me luck as well!
White96MaxSE
Get a gym membership instead!!!!
Originally posted by pocketrocket
They should last a while, unless you use the hood to work your biceps
I just replaced the hood struts today... it took 15 min. at the most. But I just realized something, you have to lift the hood almost 3/4 of the way in order for it to stay... Anyone else notice this ?
...I just realized something, you have to lift the hood almost 3/4 of the way in order for it to stay... Anyone else notice this ?
I ain't kidding you, I did balance it on my head. Won't ever do it again
i didn't know my dad knew those swear words.. i am in the NAVy.. and i can cuss pretty well, but damn.. dear old dad is a pro..!!!
Originally posted by redmaxpa007
the hood fell and hit my father on the head while we were tightening the belts...
Note to self: stop whining about dumb things.
well, easy but not painless
I just got these Strong Arm hood struts also ($15 a piece), which seem to be very good replacements.
However, everyone here is talking about 10 mins to change 'em. Well, how the heck do you get the top nut off?? I've tried three different wrenches and pliers, but I can't get to it. Guess I'll have to finally get some needle nose pliers. Can't think of any other tool that can get to it. The metal hood moldings around the nut keep blocking my movement--and I'm afraid of bending the screw hole if I try to "pop off" the top socket. What did you guys use to get your nuts off? (um, that didn't sound right... )
permanent fix
I cut a lenght of 5/8" wooden dowel long enough to be a support rod. It fits into opening holes already on the hood and the metal support in front of the radiator. I keep it stored on the passenger side of the engine compartment. Plastic "tie wraps", like those used to keep electric wires in place, keep the homemade hood support secure when not being used. Not fancy, but it works perfectly when used with my original equipment hood supports which have started to fail in cold weather.
Maxima_Joe
11-25-2015 08:19 AM
95Maxi
35
09-02-2015 10:37 AM
laparka66
08-06-2015 09:36 AM
