Most newb question: trunk lock
Before I go to the stealership or a locksmith to fix this...is there a reason my trunk won't open with a key, but will open from the switch inside?
The key goes in smoothly, but doesn't turn at all. It was fine before and then it just stopped working.
mine is like that too for some reason, but i have no intention in fixing it...i got the thing inside...and the keyless entry with it...
i would go with kevin though...hes lived it, nothing bad can happen as a result either...id assume
Originally Posted by Kevin
i push the slot in with a small screwdriver and shot some wd-40 in there. within minutes it worked just fine. did this for both doors too.
i always relied on the keyless or inside as well... only prob is, when i was in an accident and the battery was smashed, none of those handy electrical things worked... and i had stuff in the trunk i needed to get out... so i learned my lesson... better to be able to use the key just incase
Originally Posted by mrgreek
true, gl with the wd40 idea, respond back here if it works, id like to know...
if that happens to me, ill hire my buddy to crawl through the poutch opening thingy in the back seat
Nuts....sprayed WD-40 into the lock and still nothing. The key goes in fine, but it doesn't turn AT ALL. It feels like it's the wrong key.
The key worked fine before, but my dad went to get a spare key made and I guess he tried opening the trunk with it and maybe broke something? THe spare key never worked (in any of the locks) and now my real key doesn't work either.
REDinLV
10-18-2015 05:31 AM
HerpDerp1919
09-29-2015 02:02 PM
Andy29
09-29-2015 05:32 AM
