Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 03-23-2005, 12:09 AM   #1
300Z brake upgrade
can somebody help me find a link of how to install 300zx brakes on our cars?
thanx.
__________________
VQ35 Loaded....
Maxima FS with goodies
http://forums.maxima.org/maximas-sal...ly-loaded.html
Maximus_95 is offline   Reply With Quote
Old 03-23-2005, 12:41 AM   #2
I'm looking in to the same thing best I've found so far is:
F/S Dek injectors low miles 32,000
http://importnut.net/300zxbrakeswap.htm
http://www.mattblehm.com/
Hopefully someone can jump in with something more definitive, I hope this helps.
MAXRB8 is offline   Reply With Quote
Old 03-23-2005, 04:44 AM   #3
Old Maxima Legend
Ceasars Chariot's Avatar
Send a message via AIM to Ceasars Chariot Send a message via MSN to Ceasars Chariot Send a message via Yahoo to Ceasars Chariot
Items needed: '92-96 300ZX FRONT Calipers AND Rotors. *Note*: Prior to installation of the rotors, you must MILL down the RADIUS of the rotors by 3mm. THIS MUST BE DONE in order for the rotors to fit! YOU MUST DO THIS PRIOR TO INSTALLATION!, 17" Rims with clearance in the middle for the Calipers.
Optional: Front 300ZX stainless steel brake lines, new brake pads.
Tools needed: Complete Metric tool set (deep and short sockets, drivers, etc), Sheet metal cutters, torque wrench, brake fluid, brake bleeder kit, jack, jack stands, gloves, flat head screw driver, hammer, bungee cords (4), WD40, thick towel, friend
1. Start by raising the car on stands. Let's start on the driver side. Remove the wheel and place the lug nuts in a smart place. Now, we want to remove the stock caliper from the car. There are two bolts that hold it in place on the steering knuckle. They are two 17mm bolts. Remove the bottom bolt first. Now with the BUNGEE cords, loop one end to the top of your springs and the other end around a hole in the caliper so that the thing doesn't drop onto your foot. Remove the remaining bolt.
2. Now that the stock caliper is free from the body, remove the stock rotor. This might be a bit tricky, due to the fact that the rotors might be rusty and have melded themselves onto the axel. Using the thick towel as a protective barrier, hammer the rotor off the car, rotating the whole thing and striking the rotor in equal distances, until the thing pops off.. it should pop off cleanly.
3. With the rotor off, you can now see that the dust shield is PRESSED onto the steering knuckle when it was assembled, and we wish to take it off, for it will interfere with the Z caliper. Using the flat headed screw driver, chisel your way in between the dust cover and the cv joint. Wedge the screw driver in there, whack a few times and try to pull the cover off. Do this a SEVERAL different angles, until the dust cover pops off and is now loose.
4. Using the sheet metal cutters, find the thinnest portion of the dust cover and slice there, remove the dust cover completely and then proceed to throw it away. it is now USELESS.
5. OK. Now that you've gotten the dust shield off, you're almost done.. did you know that?
6. Attach the 300ZX Rotor, which should already have been milled down 3mm from the radius, onto the studs. Put in place with a few lug nuts, tighten so that they are FIRM, and that the rotor has no LATERAL movement.
7. Attach the 300ZX Caliper with the same 17mm bolts you took off of the stock caliper. Tighten it up. There should be 1-1.5mm clearance on the edges of the caliper with the rotor. IF NOT, then reinstall the caliper and retighten. IF NOT, then the rotors were not milled correctly and have them checked out!!!
8. Now, here's the tricky part. Changing the brake lines from the stock caliper two the 300ZX. Pop the hood, and open up the Brake fluid cap. Now, with one person should change the lines while one person pours in the brake fluid into the reservoir so that it does not fall below the line. This might be messy.. watch out! Remove the stock caliper, and remove the bungee cord.
9. Use the brake bleeder kit and bleed the brakes so that there is no air in the lines. Please refer to your service manual or car care professional on how to bleed brakes.
10 After the brakes have been bleed and the brake feels firm. Torque the bolts that hold the caliper to ~60 pounds
11 Repeat on other side.
12 MAKE SURE the pedal feels FIRM and not spongie. If it does, you have done something wrong and RE-BLEED the brakes.
13 Road test on a straight road with no cars! Go slow and brake. Slow. Brake. Then go for about a mile with this slow-medium speeds and soft-medium pressure in braking. Then pick up the speeds and press harder on the brake. The car should feel firm and the stopping distances should be shorter.
14 Done.
- Cheston Chiu. (maximadriver)
__________________
N/A - 97 SE - VQ30DE - 93 octane
13.8 @ 98x - 2.06 60' - USIM
13.5 @ 101 - 2.10 60' - OOVI/EU
N/A - 97 SE - VQ30DE-K Swap
TBA
Ceasars Chariot is offline   Reply With Quote
Old 03-23-2005, 10:08 AM   #4
Dang, Chariot, thanx bro.
__________________
VQ35 Loaded....
Old 03-23-2005, 10:14 AM   #5
A couple of Blaxxx's? Lawls.
slimer's Avatar
Send a message via AIM to slimer
you dont need the cutters, a dremel will work fine. make sure you have enough cutting wheels.
__________________
Holy giant sig pics...
Best Quotes EVAR
look2me40: I have no friends. No live friends. No imaginary friends. No friends period.
ABDomega: After all, more sex means I'm more of a man!
GBAUER: Especially when I'm looking for a bit of man-on-man s3x0rs.
dashan: You might be right. I should not speak at all. But I could fcuk your axshole, so be prepared.
Buffalomike: can I play in the sand box.
slimer is offline   Reply With Quote
Old 03-23-2005, 10:18 AM   #6
Spec V Sell Out
MaximaSE96's Avatar
Send a message via AIM to MaximaSE96
i beleieve wheels 16" with a +5 offset too....aka...90-96 z wheels and 87-89z wheels...i believe 1/4" spacer is needed as well...but someone can prove me wrong
__________________
I sold out and bought a Spec V...I miss my 4th Gen Maxima...
MaximaSE96 is offline   Reply With Quote
Old 03-24-2005, 01:38 AM   #7
ok, let me get this straight, to bleed the brakes kinda got me confused. it says that
"Changing the brake lines from the stock caliper two the 300ZX. Pop the hood, and open up the Brake fluid cap. Now, with one person should change the lines while one person pours in the brake fluid into the reservoir so that it does not fall below the line. This might be messy.. watch out! Remove the stock caliper, and remove the bungee cord."
so while you pour the fluid, the guy has to be changing the lines at the same time?
wouldnt it be take the line out, and face it towards a bucket and have someone pour the fluid in while it bleeds?
__________________
VQ35 Loaded....
Old 03-30-2005, 01:25 PM   #8
Did anyone with this upgrade happen to have a problem with the roto touching the lower control arm?
__________________
VQ35 Loaded....
Old 03-30-2005, 01:27 PM   #9
Send a message via AIM to KMax2988
Yup, you gotta grind that arm back till the rotor clears.
KMax2988 is offline   Reply With Quote
Old 03-30-2005, 01:58 PM   #10
Quote:
you serious? how come there was nothing mentioned about this on any write ups on how to install the 300zx brake upgrade?
Is it only for some cars?
__________________
VQ35 Loaded....
Old 03-30-2005, 02:04 PM   #11
It was mentioned on an older write up I saw quite a few years ago but it's one of those things that is easy to overlook when you're trying to explain the install process to someone else.
I've had to do it to every Maxima I installed the full Z32 front brake upgrade on.
Old 03-30-2005, 02:49 PM   #12
so just grind it down and that's all right?
anymore problems i should be aware of?
dont want to run into a problem that i cant solve and have to put everything back together again until i find out whats' wrong.
-so mill down rotors 3mm from radius.
-and grind down the lower control arm.
as far as i know, thats it right?
__________________
VQ35 Loaded....
Old 03-30-2005, 05:32 PM   #13
Donating i30 Owner
Send a message via AIM to HomerMAC
hmm damm grinding... so there is no direct bolt on .. to the caliper
__________________
HomerMAC is offline   Reply With Quote
Old 03-30-2005, 06:18 PM   #14
Sounds like you got all the technical points there. Make sure you also have new brake lines (240SX to 300ZX conversion lines are what I recommend).
Old 03-30-2005, 09:58 PM   #15
Be sure to have the correct clearance with the rims if not you will have some problems. My rims didn't have the correct clearance and I had to shave down the "NISSAN" lettering a bit.
The New CLIMAX is offline   Reply With Quote
Old 03-30-2005, 10:04 PM   #16
Quote:
oh, no worries, my wheels clear it, barely, but clears, the only thing i was worried about was that lower control arm! ill post pics of it after im done. thanx everyone for the help!
__________________
VQ35 Loaded....
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
