what are the symptoms of a bad rack & pinion, and strut mounts?
Old 03-09-2005, 04:28 PM
Stuntin' 101's Avatar
thanks in advance
Stuntin' 101 is offline
Old 03-09-2005, 07:28 PM
nick's Avatar
bad rack and pinion might have few different symptoms, to name few:
- noise while turning the wheels
-vibrations and shimmy in the steering wheel
- over all "loose" feeling in the steering wheel
- check for any leaks, torn boots , loose inner and outer tie rods,
bad and torn strut mounts will give you clunking noise while going over bumps
as the matter of fact - while installing my front springs on Tokico struts I've managed to destroy one of the strut mounts , I used impact wreanch to tighten the strut nut and the rubber inside the mount separated from the mount , dang I have to order new one online,
I'm pretty sure others might add to that list
what are your symptoms?
Nick
nick is offline
matts95max
09-09-2023 01:52 AM
wyobbagy
01-03-2023 12:03 PM
dvcamp
09-18-2015 10:17 AM
spidgeon
09-09-2015 03:36 PM
dcam0326
09-08-2015 11:02 PM
Quick Reply: what are the symptoms of a bad rack & pinion, and strut mounts?
