My 99 maxima
Old 08-05-2017, 02:27 AM
RAINRAIN123's Avatar
My 99 maxima
In my 99 maxima all of a sudden the emergency brake light and the battery light in the dash turned on while driving (flickered) But when I put it in neutral at a red light it turned off,...what could it be?
RAINRAIN123 is offline
Old 08-05-2017, 02:58 AM
CS_AR's Avatar
Most likely the alternator. See following threads. If the alternator is out, you won't be able to drive far before the battery discharges. I would also get the battery checked for a short. I've had a shorted battery knock out an alternator.
https://maxima.org/forums/4th-genera...eird-prob.html
https://maxima.org/forums/4th-genera...-lit-dash.html
CS_AR is offline
Old 08-05-2017, 04:33 AM
Turbobink's Avatar
^^^ +1 on what Craig said.
Classic alternator failure symptom.
Turbobink is offline
Old 08-05-2017, 10:50 AM
+3. Bye bye alternator. Replace it now before it leaves you stranded. But test it first to confirm it's failing.
The Wizard is offline
Old 08-05-2017, 01:07 PM
KP11520's Avatar
+4
Like they said.....
....... and also takes your battery with it. Car batteries aren't meant to be drained to zero and it only takes a few times until it gives up the ghost. Especially if it's a few years old. (usually)
KP11520 is offline
Old 08-05-2017, 01:54 PM
98 SE
93SCMax's Avatar
Check the belt condition and tension first before replacing the alternator. If the belt is worn or slipping, you could get the same condition. New multi belts are much cheaper than alternators. And don't forget to use an OEM belt if this ends up being your issue...otherwise the alternator is the likely culprit.
93SCMax is offline
