Difference between GXE, GLE, SE
#42
Originally posted by Sarah99GXE
Ijust remembered the other question I had....I notice I have the digital odo....but I don't see my trip meter?? I have the button you can push sticking out of the dash to reset it, but I don't actually see the meter that it's going to reset???
#43
Originally posted by mzmtg
Do you see one under there?
Patrick
#44
Sotck rear sway bar on every Gen4
Oooooooh!! That bar! My 98SE has it. All Gen4s must have it, then. It's just not very visible at all because it is so well integrated into the rear beam.
DW
DW
Originally posted by spreng
Yes, as a matter of fact, I do. Maybe my 1998 GLE is the only Maxima with a factory rear sway bar, but I doubt it. The 1 1/4" bar is inside the multi-link beam and is welded to the trailing arms. The stock rear sway bar is in fact integrated into the rear suspension.
Patrick
Patrick
#45
Patrick
Patrick
#46
Factory Rear Sway Bar
Well, I stand corrected. You're right. IMO, that's a sneaky thing to call a sway bar. It just seems to be part of the beam.
Patrick
#47
A GXE with the Safety & Convenience Package is not speed governed and comes with H rated tires. If the car has the S&C package it is prewired for fog lights. I haven't done it myself, but the description of the installation does not sound very difficult. I beleive the kit can be obtained for about $180.
#48
Im sure all of htis was all mentioned all ready. SE's have white guages...came color grill (on 97-99)....standard spoiler...all the options if you wanted to add them....GLE's have woodgrain...and more of a luxury look...GXE's are the basic model.
#49
#51
Re: wuts the difference perfomance wise
Originally posted by nirvan4007
wuts the difference performance wise on all the models including the quarter mile and 0-60 ,i got a 95 maxima gle
#53
What is the difference between GXE, GLE, and SE. I have a GLE, and all of the options are in the car, cd player, leather, no spoiler, but the bose sound system and all. i dont see what the difference is in a GLE and an SE but the wheels??? How do you rate the maximas between these three stock ?
useless thread, this is covered in the faq lol
#60
So on my title it says model MG? Im not sure what model my 99 is... power everything, cloth seats, no sunroof, automatic, spoiler, soft suspension, fake woodgrain inserts, steel wheels with hubcaps (could have been changed by previous owner.
#61
Do you have black or white gauges? Fog lights?
#66
#69
gxe is fine to have... Its just the base model. But a base model maxima is still a MAXIMA! Most of the options you are missing are easily swapable with the exception of AAC. Thats the automatic climate control. The speed limiter is a simple wire snip (which induces a CEL), or an ecu swap. Sportier suspension is a 30 minute job and seats are about the easiest thing you can do! Just takes some coinage...
Just be happy youve got a Max!
#70
Se any gle difference
The. Se maxima. Comes with traction control which is wired to the transmission it also has heated seats now I have a gle maxima it doesn't have traction control or heated seats and the motor is slight different the se model was sporty the gle was luxury and to my guess the gxe was basic I'm speaking on the 2000 models not 01 or 02,,,,there's a slight different between the gle and se model when it comes to the engine the se has a green connector that's not on gle here's a pic
On the passenger side of the motor to the rear of the timming plate this connectior is for something but i dont know what nor does any mechanic or the 4 shops i took it too
kkmmk
kkmmk
#72
tarun900
19
12-20-2021 06:57 PM
AaronL
08-08-2020 10:31 AM
Unclejunebug
04-02-2016 05:42 AM
Need help
23
10-02-2015 08:56 AM
