Car dies on idle (random times)
Old 01-01-2005, 11:02 AM
multiplexor's Avatar
Hey guys,
Last night when i was driving to a new years party, my car stalled at a stop. I was like... uhm ok.... so i start it, and notice it's having a rough idle... so i take off... get to my destination and the car just stalls again. I start it, it stalls, start, stall... i start it, floor it and it stays on when i'm pressing the gas. When not, it stalls again. I like giving things time, so i goto my party, later that night come out to start it and leave (sober ) and it starts fine.
I drop some friends off about 5miles down and when i stop there, it stalls.
I start it up, it's ok again, I get home and it's got a semi decent idle...
any ideas whats going on? I know my coil packs are not all measuring the same resistance...
Could it be the fuel pump? coil packs?
note, i was also getting hesitation when on the road... the car sometimes felt like it was losing power and then it would come back. Like a knock sensor sudennly going bad, then coming back again...
Any ideas guys?
Car: 96 maxima, manual trans, 122,000 miles
multiplexor is offline
Old 01-01-2005, 12:13 PM
MDeezy's Avatar
if you know your some of your coils arent mesauring the right resistance then you know those will need to be replaced.
Check vacuum lines make sure there are no holes or leaks (but if you had one I'd like to think that you'd stall all the time, not stall then fine then stall then fine.)
check Maf.
Hmmm . . thinking what else. . .
MDeezy is offline
Old 01-01-2005, 01:46 PM
njmaxseltd's Avatar
Sounds like a dying MAF sensor.
njmaxseltd is offline
Old 01-01-2005, 01:48 PM
kcryan's Avatar
vacum lines or a tb in need of cleaning really bad? mabye coils
kcryan is offline
Old 01-01-2005, 02:21 PM
2 Da Max's Avatar
bad coils on a 96 hmm doubt it, sounds like maf goes into protect kinda. does it go past a certain rpm?
2 Da Max is offline
Old 01-01-2005, 07:18 PM
cefiro a32's Avatar
I had a similar problem recently. I checked the ecu which gave me code 0304(knock sensor). I replaced the sensor and the car drives like a dream. Check your ecu
cefiro a32 is offline
Old 01-01-2005, 09:10 PM
2 Da Max's Avatar
ks wount cause the car to die. just retards thet timing
2 Da Max is offline
Old 01-01-2005, 10:46 PM
nismology's Avatar
FUEL FILTER!!! That would be the first thing i replaced.
nismology is offline
Lakersallday24
06-16-2019 01:35 AM
maxinout93
10-27-2015 01:29 PM
Balkins
08-12-2015 06:39 AM
Maxboy23
08-11-2015 11:59 AM
Quick Reply: Car dies on idle (random times)
