Window Defrosters
Window Defrosters
Now that it's starting to get really cold, i'll be driving along with my window defroster at full tilt and my rear drivers side window will not defrost. Sometimes my drivers side won't defrost either. Just wondering if this has happened to anyone and if there is anything i can do to fix it. Also, my rear window defroster takes a while to clear the back window and if anyone knows about that either, it would be great. Thanks.
I know you must need them in ottowa, winters were very cold and snowy in toronto. if you have any extra few minutes you could use a scrapper for the sides of your windows and let the defrosters do the rest for your front and rear.
Are you asking about ice/frost on the driver's side windows, or condensation on them? If you're talking about condensation (side windows being fogged up), that's all related to body heat colliding with the cold outdoor air - not much to do about that except to occassionally roll down the window to help clear it. Losing weight helps (hehehehe), but I'm a skinny bastard and it still fogs up on me. Running the climate control on front defroster or front defroster/legs blows some air on the front door windows, but not enough to clear them entirely.
As for the rear defroster taking a while - so does mine. Especially if the window has visible ice built up on it. I think it does a pretty good job, but I wish it would clear the ENTIRE rear window. In addition to MDeezy's advice, scraping the front and rear windows a bit helps the defrosters work better and quicker. You don't need to give 100%, but just break the ice up enough that its not a solid mass and has some thin/clear patches.
My '96 has the driver's side mirror heated (I think it was part of an optional package Nissan installed, like a cold weather package). Is the passenger side mirror supposed to heat as well?
If not, has anyone found a way to heat it? The heater mirror I have works GREAT! Even steams away the rain when its raining out so it keeps the mirror clear! I want the passenger side mirror heated bad!
Mike
Mike
Originally Posted by Conrad283
The windows are fogged up because of the change in temp. So if it's really cold out, blow the defroster with the thermostat set on cold. That should work.
Hehehehe, assuming you don't want to be very warm for the next few months
I read somewhere that putting shaving cream on a window will keep it from fogging up, but who wants shaving cream all over there window, unless you figured out a way to mix it with windex. I think I read it in maxim or stuff magazine.
Mike
Mike
i wonder who the first person was who thought "hey, let me try to put shaving cream on my windows to see if it cures fogged-up windows?"
REDinLV
10-18-2015 05:31 AM
