How long does it take for the ECU to get it's readings?
Old 11-29-2004, 12:16 PM
NetFurie's Avatar
Emissions test time. Like a dumba$$, I reset the ECU right before I went to get it tested to get rid of my vehicle speed sensor code (they won't test if the cel is on.)
I failed because half the readings were "not ready."
Anyone know how long it takes? The GA State guide they gave me says 2 weeks but if I wait that long I have to pay some kind of late fee for the tag. I guessing it has more to do with miles driven than time, but not sure.
Gavin
NetFurie is offline
Old 11-29-2004, 02:53 PM
maxima_kid's Avatar
Depends on whats the problem but drive it around for about an hour. Should come up within that time. Otherwise keep driving.
maxima_kid is offline
Old 11-30-2004, 07:57 AM
NetFurie's Avatar
Do you know of a way to tell when the ECU is "ready?"
When you fail an emissions test here in GA you get one more test for free. If you fail again you have to start paying again.
The only reason I failed is that about half of the readings came up "not ready."
NetFurie is offline
Old 11-30-2004, 10:10 AM
njmaxseltd's Avatar
The ECU is always ready. Resetting it only clears stored error codes, it does not reset or change any operating parameters. Your car should be fully warmed up, well into operating temperature before you go for an inspection. That assures your emissions systems are working correctly and helps you pass a smog test. State inspections will plug into your cars ECU and look for any stored error coeds. If they find one, you will fail the inspection.
njmaxseltd is offline
Old 11-30-2004, 10:21 AM
NetFurie's Avatar
Perhaps that's the problem. It was only about 2 miles to the inspector; temp needle was where is usually is by then but maybe I should driven a little longer.
NetFurie is offline
Old 11-30-2004, 10:24 AM
A32Matt's Avatar
resetting the ecu does reset the OBDII emissions moniters. There is a certain drive sequence you have to do that the dealer has, but it is an extreme pain to do. From my experience as an emission tester, you have to drive around for at least 1-2 weeks before your moniters are back to normal. We've had people drive around for a month and their moniters still weren't ready for testing which would cause them to fail.
A32Matt is offline
Old 11-30-2004, 10:58 AM
NetFurie's Avatar
cool. Thanks for the info! I may give the dealer a shout and find out what the drive sequence is.
NetFurie is offline
matts95max
09-09-2023 01:52 AM
mvm062
11-30-2020 09:00 AM
captchaos
03-15-2016 12:18 PM
mix master
09-04-2015 05:50 PM
Quick Reply: How long does it take for the ECU to get it's readings?
