5TH gen pressure plate a success.
#41
I'm nutty for Nissans
Originally Posted by 96stillen_max
i got a chance to really give the 5th gen clutch assembly a thorough test last night. i was driving around and found another 4th gen
this thing grips like crazy. yesterday i was having some doubts but last night set me straight. i did a really hard launch on it and. then came the 1-2 shift with a ton of wheel hop and then every shift after that just went really nicely.
you have no idea how nice this is after having that damn key value clutch for 5 months.
Same here. I get mad wheel hop, like loud banging......not good for anything. That means I'll take it easy untill I get some type of reinforced/poly filled motor mounts. I get 0 traction in 1st and 2nd gear....my winter tires are just crap. It gets all squirrely. I never had this kind of power with my old clutch, even from day one. the 2-3 shift is so instantaneous, clutch in.....shift...release....power! its really nice to feel what my car is really capable of. I went to the track often, getting close to stock times, best was 15.1@92.8. I know this clutch will bring me into the 14's.
#43
I'm picking the parts up today. Do you by chance know "what degree to turn the flywheel at?" <---my mech. asked me to find that out for him. After my clutch, I have to do some general maintenence (spark plugs, filters, etc.), and then my knock sensor, and then my car is going to feel like a champ. Even with a dead ks, the new clutch will be putting all of the power I do have down, and therefore will feel grrrrreeeeeaaaaaaaaaat!
#44
So anyway...I didn't read all the posts cause in the middle I got bored reading of a guy who was asking you how hard the work was. Basically...if my clutch was to go...I'd buy everything for the 4th gen EXCEPT the PP? Which I'd get from a 5th gen? Meaning the only 5th gen part in the job you did was the PP? Thanks.
#45
/end of story time
sorry if i came off as a jerk, but your non-modivation to read through a 1-2 page thread bothred me..
Anyways, hope i cleared up your question...
#46
I'm sorry for bothering you. It's just I'm in class and all. Plus, really, the guy talking about how hard the job was was bothering ME. Oh well...thank you for your help. As always, this place rules. Some people just have a different way of sharing information and that was yours. All is well .
#47
Yes, and the .org does rock.
#48
Its not bad of a job if you have certin tools. I just replaced the tranny and it took about 7-8 hours by my self. Racheting wrenches are worth their weight in gold. Without them you have to drop the cross member, which means taking off the y pipe and that alone can open a huge can of worms.
There have been some recent threads about which disc to use. Apparently there are 2 5th gen 3.0 discs, suposedly one smaller than the other. Also there are suposedly 2 different pressure plates (aka clutch cover) with different clamping pressures. At the time I didnt know about the 2 PP, so try an dig up the other thread. I would think the best one would be on the 2001 AE Max because of the 227 hp rating. Mine has higher clamping force than the original 4th gen, but there could be a stronger one too.
#49
Thanks for the info jstutter. How is your clutch now? Still holding up strong? I'm thinking about doing this to replace my exedy stage one which looks to be about the same clamping force as the 5th gen setup..
#52
If I'm not mistaken, DaveB clarified that the early PP was the beefier clutch cover, I thought you had talked to him about that.... Guess I'll be looking at the old threads sooner or later.
I had been meaning to go back and gather everything together to put in the stickies....but I have so much crap subscribed now, and the numbers for the parts have changed since the very beginning when only the three of us (known to me/us anyways) had this done. Oh well, I've got time on my hands since I work at nights....so maybe I can motivate myself now.
And just to add another thing...my clutch has been perfect since day one as well - did 12 runs down the track in one night without any problems, and has enough clamp to chirp second without laying down the throttle (if that says anything...ha ) Another way to say it...just like Jon, the 2-3 shift is instaneous still, and daily driving is extremely comfortable...not too stiff but definately great feedback.
#53
so i have a 96 i30 with the LSD
would there be any probs with using the 5th gen stuff in mine.
so you guys used the 5th gen clutch, pressure plate?
and also the bearing sound, it sounds like something whirling inside... did you remove the bearing to get rid of that sound? if so what is the exact bearing you guys removed...
#54
no u wont have a problem....the bearing they are talking about is the Throw out bearing u really cant miss it once the tranny is out of the car....theya re like 30 bux so it best to replace while everything is out
#55
so im gonna replace the throwout bearing, 5th gen pressure plate, clutch, seals,
now what about the flywheel? should i do anything here.
sorry be such a nag. but im really more elctronics etc. and i wanna open up the tranny tmmrw at a shop and have them do EVERYTHING. while its out.. cause iim paying 500$ labor... and that will cover everything..... no matter what i do under there so i wanna get everythign out of the way..
#56
its not really a problem....it just wears out like a clutch does....so say i have 115k on original clutch and TO Bearing...they both will start to wear out....the flywheel usually just needs to be reasurfaced to be true.....other than that i would get some MT-90 Gear Lube and be on my way
#64
Originally Posted by HomerMAC
How may i rectify this? what do i have to change...
#65
Originally Posted by Penguin1996
i have the same EXACT problem but only on 3rd, not 4th (previous owner beat the crap out of the tranny). if you step on the clutch and leave the shifter in 3rd it just slides right into neutral after 3 seconds and if you try to pop it back in while its popping out youll hear the gears grind. yeah man i know.....tranny issue....aint got nothin to do with the clutch
#66
okay well now im runnign the 5th gen pressure plate and clutch... and i must say its BEAUTIFUL..
my mech. jsut to make shure eveyrthing is catching rite.. he buurnned rubber in the lot... (i was abit conserned cause there wasnt much space...)
but yea.. ive been grannyin gher around.. and its beautiful... 1st gear is AMAZING.... barely any gass needed and its amazing..
ohh man i love it... thanks for the poeple that were the test subjects earlier...
#70
well the thing i found said 99+ Silvia not 240sx so i would have to say JDM= sr20det....
http://www.courtesyparts.com/Merchan...Category_Code=
#72
well the VQ30 seems to love it... ohh soo soo beautiful.. JSutter thanks for bringing up this thread rite at the nick of time when im was going to work shop... I LOVE IT
#77
Originally Posted by kingrukus
Besides build date, is there any reason why one should opt for the 30210-89F00 over the 30210-2Y920 pressure plate (or vice-versa)??
30210-89F00 - 240 mm dia. 635 kg
30210-2Y920 - 250 mm dia. 750 kg
I am using the 2Y920 with a VQ35 coupled to my 98 5-speed VLSD tranny with no issues.
#78
#80
So essentially the 30210-2Y920 has a higher pressure threshold and is ultimately the better choice for more grab, correct?
