Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos Classifieds FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Sponsored by: FCP Import
Click Here
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 10-30-2004, 12:49 PM   #1
Points: 9,905, Level: 66
Points: 9,905, Level: 66 Points: 9,905, Level: 66 Points: 9,905, Level: 66
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
How to replace control arm bushings?
I need help, i bought ES bushings from courtesy and i spent 3 hours today trying to remove old ones, i can't get stock bushings off? they look like they are glued on. I managed to take all of the bolts off but i cant seperate old bushings from the control arm. And new bushings seem too large, anybody know how to put them on? If anyone has done this give me some tips.
__________________
95 GLE
GreenMachine
BluFlame is offline   Reply With Quote
Old 10-31-2004, 09:16 PM   #2
Points: 8,004, Level: 60
Points: 8,004, Level: 60 Points: 8,004, Level: 60 Points: 8,004, Level: 60
Activity: 0%
i did it awhile back
i use a press to punch out the old bushings
or it was suggested me to burn it out
then use the press to put the new once
goodluck
kitmaxima is offline   Reply With Quote
Old 10-31-2004, 09:50 PM   #3
Send a message via AIM to Ant96GLE Send a message via MSN to Ant96GLE Send a message via Yahoo to Ant96GLE
Yea you can burn them out but you'll definately need to get them pressed in...
__________________
Ant96GLE is offline   Reply With Quote
Old 10-31-2004, 10:54 PM   #4
I burned out and drilled out old rubber on bushings, then used a hack saw to cut thru 1mm or less sleeves that hold the rubber in place. Used screwdriver to pry them out with minimal force.
Used a vice to push the new bushing setup back in.
izzydig is offline   Reply With Quote
Old 11-01-2004, 05:23 AM   #5
Minister of Silly Walks
mzmtg's Avatar
Points: 37,185, Level: 100
Points: 37,185, Level: 100 Points: 37,185, Level: 100 Points: 37,185, Level: 100
Activity: 0%
Send a message via AIM to mzmtg
Quote:
The new ones DO NOT need to be pressed in. They slip right in with minimal effort.
__________________
2001 Xterra XE
mzmtg is offline   Reply With Quote
Old 11-01-2004, 07:01 PM   #6
Activity: 0%
It took me 4hrs to put the new one in, i could only replace one bushing (pivot). ES bushings were simply too big, i had to remove some material from them with dremel, i know it defeated the purpose of putting new ones in but i did this without removing the control arm from the car. Ride is ok so far, i feel aligment is off. I think GLE has a different bushing setup than other models.
My originals were torn off and i didnt feel like spending $200 on a whole assembly, this way i only spent $30.
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
