High idle at red lights
My max has a wierd idle. When you start the car it idles normally (ie a little higher when it's cold but drops down once it reaches operating temp). Over the last few weeks it has developed this issue where after I drive at speed, sometimes over a long distance and sometimes between lights, and come back to a stop, the idle is high (1500rpm or so). If I blip the throttle it goes down to where it is supposed to idle (750rpm?). Gas pedal doesn't stick or anything. Any input is appreciated.
1995 Maxima SE
181,XXX miles
5 speed
No Mods
1995 Maxima SE
181,XXX miles
5 speed
No Mods
PCV valve?
Just a thought. It's a $4 part and changing it takes 5 minutes.
Good luck,
TOM
on the sticky IACV... mine did exactly the same thing (high-idle in stop/go traffic, etc.). I took off the IACV and gave it a good scrub with some throttle-body cleaner (not carb-cleaner)... I also cleaned out the TB at the same time... its been fine since.
220k+ A32
08-17-2015 03:57 PM
MikesChevelle
08-06-2015 11:36 AM
