installing stillen intake help
Old 09-12-2004, 10:26 AM
sunysb83's Avatar
i was installing my stillen hi-flow intake i just got, but ran into a few problems along the way. i need help locating the ambient air temperature sensor (A.A.T.S), there are so much wires and plugs and i am not sure which one it is. Also, how do you recommend i get the bolts and screws off the MAF sensor from the airbox top and how do i get the screws off the bottom half from the car. I got most of them off, but a few won't budge at all.
thanks for help
sunysb83 is offline
Old 09-12-2004, 01:35 PM
I'm nutty for Nissans
JSutter's Avatar
All the bolts are 10mm, so for the bottom stock box use a ratchet and extentions. The MAF bolts you can use a ratchet for 3 but one needs a open ended wrench or ratcheting wrench. There is all so a bolt that holds some wires to the top half of the box.
As for the temp sensor its in the stock air snorkel tube. its a little probe in a rubber grommet. It pulls out of the tube. If you have a hole in the end of the stillen filter this is where it is supposed to go, but not to many ppl do it. I had to extend the wires to make it reach. Its okay if you leave it sitting somewhere in the engine bay.
JSutter is offline
Old 09-12-2004, 05:13 PM
sunysb83's Avatar
thanx, there is a hole at the end of the filter like the one in your pic. since you said you have to extend the temp sensor, would it be ok if i not touch it at all and just leave it where it is? im going to try to take a look at it tomorrow if i have time.
sunysb83 is offline
Old 09-12-2004, 05:16 PM
sunysb83's Avatar
ooooh, one more question, what kind of midpipe you have there connected to the MAF in the pic? it looks nicer
sunysb83 is offline
Old 09-12-2004, 05:30 PM
Offset Is Everything.
MrDicks95SE's Avatar
you can just leave the air temp sensor hanging where it is. if you think about it, it really doesnt make that much a difference since its taking air from inside the engine bay anyways.
i put mine in, but i didnt have to extend any wires:
MrDicks95SE is offline
Old 09-12-2004, 05:58 PM
JSutter's Avatar
I have a custom mid pipe. No you dont have to move the sensor, But you need to plug the hole. When I got my filter it had a bolt washer and nut plugging the hole.
yea 95/96 have a different sensor.
JSutter is offline
A32goldylocks
09-02-2015 06:39 AM
sonic7
08-20-2015 12:23 PM
Dman1989
19
08-17-2015 03:44 AM
Team STILLEN
08-10-2015 04:29 PM
Quick Reply: installing stillen intake help
