Timing Chain Tensioner
Old 09-10-2004, 09:50 AM
FormorAccordMan's Avatar
Can it go bad in only 52k miles? I have the knocking noise only at idle up to 3-5 MPH. ALso the timing chain is located on the left side of the block right? I need to look around the engine to seek where the noise is coming from, but it is difficult. IS it the sliver plate looking thing that is on the left side of the enigine block torwards the front? Anybody have a pic? Thanks, and sorry for the dumb question.
FormorAccordMan is offline
Old 09-10-2004, 09:53 AM
I'm needing a caw
Jeff92se's Avatar
Try the search, it works now
Jeff92se is offline
Old 09-10-2004, 09:55 AM
I just went to try and search, but it says that it is turned off to reserve resources.
I'm needing a caw
Jeff92se's Avatar
search this forum feature
Jeff92se is offline
Old 09-10-2004, 09:58 AM
where is that located on the interface? I am looking for it. Thanks again
Old 09-10-2004, 09:59 AM
I'm needing a caw
Jeff92se's Avatar
4 gen section. Not in individual threads
Jeff92se is offline
Old 09-10-2004, 10:00 AM
Thanks- Damn you fast!
Old 09-10-2004, 10:02 AM
I'm needing a caw
Jeff92se's Avatar
No problem. Now spread the word ya hear?
Jeff92se is offline
Old 09-10-2004, 10:04 AM
I will spread the word- But I STILL cant find the feature. I go into the actual list of threads page, and i looked in forum tools etc. Still no dice. I know I am gonna go "DUH" when i find it. take me by the hand please? LOL
Old 09-10-2004, 10:48 AM
Dreizehn's Avatar
Timing chain is on the front of the motor (passenger side).
Dreizehn is offline
Old 09-10-2004, 10:49 AM
I'm needing a caw
Jeff92se's Avatar
Threads in Forum: 4th Generation (1995-1999) Forum Tools Search this Forum
Jeff92se is offline
Old 09-10-2004, 11:00 AM
In the forum tools there are only these options:
Post new Thread
Mark this forum read
Subscribe to forum
View Parent Forum.
Am I an idiot or something?.......Don't answer that.
Old 09-10-2004, 11:03 AM
I'm needing a caw
Jeff92se's Avatar
Maybe it's a moderator thing only. Dunno. Should be right next to the "forum tools" option.
Jeff92se is offline
Old 09-10-2004, 11:09 AM
I guess so....oh well. Thanks anyway.
Old 09-10-2004, 11:26 AM
Stephen Max's Avatar
Here is a picture, courtesy of ejj (thanks, Eric!).
Access to the timing chain tensioner is through a black cover on the left side of the engine as you are facing the timing cover.
The silver plate you are talking about is the water pump cover.
Stephen Max is offline
Old 09-10-2004, 11:29 AM
Awesome! Thank you- So I am going to pop the hood and look for a black cover- how big is this cover?? I am basicall y gonna try to put my ear to it.
Old 09-10-2004, 11:37 AM
It's about the size of the water pump cover. Approximately 4"x4".
Old 09-10-2004, 09:12 PM
maximabebe's Avatar
How impossible is it to replace the tensioner with the motor in the engine bay? Mine has been rattling for some time now and I don't want to get used to hearing it. Other than that, my VQ is an awesome engine.
maximabebe is offline
Old 09-12-2004, 06:11 PM
It's a bit difficult because of limited access space. It helps if you disconnect the power steering lines and move them out of the way. After you remove the black cover plate, stuff some rags down into the timing case underneath the tensioner so that they will catch any bolts or the spring and plunger if you drop them into the timing case.
sctludwig
09-01-2022 01:32 PM
mvm062
11-30-2020 09:00 AM
kjlouis
10-03-2015 05:29 AM
trungg86
09-04-2015 04:58 AM
Wareagle92
09-03-2015 07:18 PM
Quick Reply: Timing Chain Tensioner
