Clutch problem
Old 08-22-2004, 10:11 PM
macallik's Avatar
Clutch problem
I was on the way home this evening and my clutch pedal was way too soft, and when i tried to shift gears I had to litterally jam it into gear. Does any one have any idea what this may be? It is hard to get it in any gear.
macallik is offline
Old 08-23-2004, 06:52 AM
PLUMMAXSE's Avatar
Try checking your clutch fluid. Sounds to me like you have a leak in the clutch cyl.
PLUMMAXSE is offline
Old 08-23-2004, 09:43 AM
Pappa Grande's Avatar
Or you need a new clutch.
Pappa Grande is offline
Old 08-23-2004, 03:07 PM
macallik's Avatar
I chcek the clutch fluid and it was empty. So I filled it up and bled the system but now the clutch pedal stays to the floor. It must have a leak because it shouldn't have been empty.
macallik is offline
Old 08-23-2004, 06:26 PM
Custom User Title
Nismo3112's Avatar
Bump!!!!!!
Nismo3112 is offline
Old 08-23-2004, 06:34 PM
Custom User Title
Nismo3112's Avatar
I'm also having trouble bleeding... I am replacing the hydraulic lines and master cyl.
Old 08-23-2004, 07:55 PM
Max96LSU's Avatar
Here you go, this may help...
http://www.motorvate.ca/mvp.php/802
Max96LSU is offline
Old 08-23-2004, 08:49 PM
matty's Avatar
sounds like a slave cyl
-matt
matty is offline
Old 08-24-2004, 09:28 AM
wildmaxi's Avatar
Had the same problem....how often do you have to fill the reservoir?....does your car seem to hesistate big time when driving ..tach high but goes not where...if so...your clutch is slipping and that means you need a new clutch
wildmaxi is offline
Old 08-24-2004, 11:30 AM
macallik's Avatar
my clutch doesn't slip, but i had to fill up the fluid every couple of weeks. I just thinks there is a leak. how much did you all pay for the master and slave cylinders?
macallik is offline
Old 08-24-2004, 01:29 PM
Custom User Title
Nismo3112's Avatar
I'm doin a 5spd conversion, a new master was $48 shipped.. the slave, I bought a rebuild kit for $4.
Old 08-24-2004, 02:13 PM
PAREDLINE's Avatar
slave cylinder. Easy fix. Feels good to step on a nice tight clutch. Almost as nice as a nice tight....
PAREDLINE is offline
03-12-2020 12:06 AM
BkGreen97
04-02-2016 05:47 AM
Excalibur23
10-13-2015 04:33 PM
pears
09-18-2015 05:25 AM
slowlifer
09-08-2015 05:53 AM
Quick Reply: Clutch problem
