Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-21-2004, 09:34 PM   #1
I'm nutty for Nissans
JSutter's Avatar
Send a message via AIM to JSutter
Leather boots write up and review
There is a good write up to be found at http://www.bestshiftboots.com/MaximaA32install.shtm but I wanted to get a bit more detailed and to give a review. I bought the Shifter and E Brake boots from http://www.bestshiftboots.com/MaximaA32product.shtm
(RedlineGoods.com). Here is how it went.
1) Remove the shift knob (unscrews counter clockwise), pull up the shifter trim starting form the rear. There are 4 clips total. Finally unplug the 12-volt ACC outlet.
2) Take the old boot out of the shifter trim. Notice the stock boot has a ring, rubber band, and spacer/shaper thing. I didn’t use them with the new boot.
3) Cut the bottom of the old boot, with a razor blade, to get the wire ring out.
4) Cut the wire ring anywhere; I chose the original tack weld. I cut a tiny piece out, because the butt connector took up a bit of space.
5) I sanded the wire because it was rusty. Not for looks since you cannot see it, but for ease of sliding the wire through the boot. Go ahead and thread the wire through the boot.
6) I used a butt connector to put the ring back together. It was not fun trying to crimp it though because there is not much room. I had the wire splice moved to a corner of the boot and crimped it the best I could, then pushed the ring around till I liked where it was.
7) That is it! Now you can reinstall in the reverse.
I pulled the boot up a bit over my shift knob. I think it looks really nice. Other wise the boot opening is too large and looks funny. You may be able to use the stock ring, rubber band, and spacer thing and make it look fine but I chose not to. Also my shift trim is rather beat up. It is broken in one place and the front and rear boot holder grooves are broken. I still got a good fit, and an unbroken one may need some fooling around with too. This is because the new boot is thicker and will not fit the grooves as well. Should not be too hard though.
JSutter is offline   Reply With Quote
Old 08-21-2004, 09:36 PM   #2
JSutter's Avatar
If you bought the matching E brake boot, and I hope you did, here is what to do.
1) Start with step 1 from above.
2) Using a Phillips screwdriver unscrew the one screw holding in the ashtray and remove it. There is 1 more clip holding it in on the right side, open it up and pull it out, then unplug it.
3) There are 2 screws to remove from the front of the center console; they connect to the dash. Then there are 2 more screws holding the rear of the console to the floor. You may have to move the front seats forward to see them. Unscrew them.
4) Pull the E brake up and unsnap the stock boot. Pull the whole console up, unplug the heated seat switched if need be.
5) Remove the boot from the console.
6) Follow steps 3 through 6 from above.
7) I found that the boot didn’t fit the console like the old one because it is thicker; just like the shifter boot. I cut the console a bit where the boot sits. There are 2 channels that the long sides of the boot sit into. I cut them so they are flat now, like tabs. This doesn’t hurt anything and you cannot see it.
8) Now the boot fits great! So install it.
9) Installation is the same as disassembly, well just in reverse.
It is not a bad idea to clean everything while it is apart. I know my center console was dirty. You can also use you favorite leather cleaner now on your REAL leather boots!
Before:
After:
Looks sweet!
Don't mind the dirty interior!
The look is great, the fit is nice, quality rocks, and the price was perfect. I have bought from them before and they have satisfied me both times. The other purchase was just an E brake boot for the 96 and the only think I don't like is the hole the handle sticks out of is rather large. It looks like a very loose fit. But it poses no problems. Shipping comes from Poland, and doesn’t take too long at all. Comes in a bubble wrapped envelope. No matter how you slice it I would go back for more anytime. I suggest you take a look at their products, they do have more than just Maxima boots.
__________________
-Jon
Daily driver: 98 Maxima SE ... 14.9 @ 95
09 Drag car: 94 Sentra E ... 1/8: 8.2 @ 94, 2.1 60' 356whp/322wtq
06 Drag car: 91 Sentra SE-R ... 1/8: 8.6@ 86, 1/4: 13.1 @ 110, 2.2 60' 250whp
Old 08-21-2004, 09:41 PM   #3
JSutter's Avatar
Here is the 96 E brake boot:
Tell me about any problems/ mistakes in my write up. I should get some more pix of the center console removal, but who knows. Any other questions just ask!l
Old 09-12-2004, 10:55 PM   #4
JSutter's Avatar
bump 12345
Old 09-13-2004, 02:23 AM   #5
Not bad... I like the momo boot. but nice job
__________________
I'm Rick James bi+ch!!
Keyser Skoze is offline   Reply With Quote
Old 09-13-2004, 06:44 AM   #6
Looks great. I'm thinkin of replacing my stock ugly boots aswell. You had to remove your whole center console? (was too lazy to read the whole writeup ) And are you serious? Poland? I wonder if its 60 bucks shipped here in Europe too.
euromax is offline   Reply With Quote
Old 09-13-2004, 08:07 AM   #7
Send a message via AIM to ILLeSt MaX Send a message via MSN to ILLeSt MaX Send a message via Yahoo to ILLeSt MaX
real nice job... i plan on buying my whole interior with the matching brake boot from leatherseats.com
ILLeSt MaX is offline   Reply With Quote
Old 09-13-2004, 11:36 AM   #8
Hmm wonder if anyone have any experiense on those covers? I dont have leather interior and it sucks
Old 10-30-2004, 02:26 AM   #9
So the top of the boot is just pulled up over the bottom of the shift knob? What keeps it from falling down?
The instruction on the web site don't mention the top of the boot, but the opening is definitely a lot bigger than the shaft, so it's not a tight fit at the top by any means.
I wonder if the rubber piece from the stock shift boot could be re-used, but it looks problematic since the leather is thicker than the stock vinyl.
The other thought is the same technique someone mentioned in an earlier post for the brake boot, that of turning the boot inside out and securing the top of the boot to the shaft with a zip tie.
I bought a full set (shift boot, ebrake boot, and armrest cover) but they are a Christmas gift, so they won't get installed for another 2 months.
haysdb is offline   Reply With Quote
Old 10-30-2004, 07:03 AM   #10
Nice write-up, do you have a link from where your ordered from?
dallas0593 is offline   Reply With Quote
Old 10-30-2004, 07:26 AM   #11
Send a message via AIM to Sprint
thats my write up those are my hands but thats my cousin's car
Sprint is offline   Reply With Quote
Old 10-30-2004, 07:26 AM   #12
Send a message via AIM to Nomad
Hmm made new boots myself, I used old boot as template, can put some pics.
Nomad is offline   Reply With Quote
Old 10-30-2004, 07:28 AM   #13
Quote:
http://www.redlinegoods.com/index.shtm
Old 10-30-2004, 08:23 AM   #14
JSutter's Avatar
Yes the top is much larger than the stock part, so using the ring, rubber band, and spacer/shaper thing would cause the boot to wrinkle up and look like a balloon knot. I like the boot up higher on the knob anyway. Using a zip tie on the other side may work. I have the boot pulled up high and it stays where you see it in the pic. Any other knob and it wont stay im sure.
sprinty have you gone jump happy?
__________________
-Jon
Old 10-30-2004, 09:09 AM   #15
Send a message via AIM to Max Mutes Send a message via Yahoo to Max Mutes
Ay JSutter, nice write up. I need one for my E-Brake so I will be using this soon. Also just curious, does your center console have a Ashtray in the back?
Max Mutes is offline   Reply With Quote
Old 10-30-2004, 09:58 AM   #16
Send a message via AIM to image
These are my 2 boots bought from redline goods. I cant get the ebrake boot to fit the handle on my momo handle. Nor do i know how to hide that gap over the shifter. EEEK!
image is offline   Reply With Quote
Old 10-30-2004, 10:28 AM   #17
JSutter's Avatar
Max Mutes: 95/96 have different consoles (with rear ash tray) than 97-99
image: is the momo handle larger around? eek. I bet it looks great but if you cannot get the boot on
I think the bst way to hide the gap would be to wrap the shifter rod with some electrical tape so the boot wont fall down.
BTW i have a brand new set in black, same as pictured, for sale.......the same price as the site. anyone interested?
__________________
-Jon
Old 10-30-2004, 12:53 PM   #18
image, I just get a red x where the image is supposed to be.
Old 05-06-2005, 08:17 AM   #19
Send a message via AIM to 96mAx2fast
Custom boots look great!!!
__________________
For Sale: Tons of 4th gen Maxima Parts
Inquire via email:wg00@optonline.net
*Minutes from NYC*
96mAx2fast is offline   Reply With Quote
Old 05-06-2005, 08:37 AM   #20
Team Ramrod
lilaclucymaxima's Avatar
Send a message via AIM to lilaclucymaxima
Sweet man, looks good. Nice job
lilaclucymaxima is offline   Reply With Quote
Old 12-12-2005, 07:49 PM   #21
Any writeups on how to take the center console apart on a 4th Gen Auto?
Gixxed_Spyder is offline   Reply With Quote
Old 12-12-2005, 08:09 PM   #22
JSutter's Avatar
its pretty much the same. you dont have to unscrew the knob. the trim will come off if you turn it side ways and maneuver it up and around the shifter. it may help to take it out of park.
__________________
-Jon
Old 12-12-2005, 09:33 PM   #23
Send a message via AIM to DR-Max Send a message via MSN to DR-Max
I pm'd you the second time and still no response.
JSutter, compare the old boot to the Redlinegoods one, how much thicker is it??
Quote:
DR-Max is offline   Reply With Quote
Old 12-13-2005, 01:57 PM   #24
JSutter's Avatar
way thicker, think jeans vs real leather.
__________________
-Jon
Old 12-13-2005, 02:06 PM   #25
Thanks. I have the same thing right now, but not from Redlinegoods and I can't stand the way it just bundles up down there especially now that I have an STS. I want something way thinner.
Old 12-13-2005, 03:47 PM   #26
JSutter's Avatar
i pulled mine up around the shift knob and its not too bad. about 1" higher than in the pic. i have an sts and it would be nice to have a shorter boot but looks great as is, so im not complaining.
__________________
-Jon
Old 07-07-2009, 06:27 PM   #27
So can I do this wit a auto. and get rid of the R,D,N, & so on. And just have the boot??
bostonsbest is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
