creaking sound when turning-- help!!
Old 08-20-2004, 10:26 PM
Tuna's Avatar
well i get this creaking sound on the right hand side when i turn while standin still.. could this be my strut mount?? i got a strut bar and some agx's installed.. if it is a strut mount how much am i lookin to get it fixed and what kind of damage would it cause if left like that for another month or so??
any help is appreciated
TIA -tuna
Tuna is offline
Old 08-20-2004, 10:49 PM
Hooooooonda.....
DAVE Sz's Avatar
strut bearing, does it also happen when making turns at slow speeds? is it a wind up then pop kind of sound?
DAVE Sz is offline
Old 08-20-2004, 11:58 PM
Tuna's Avatar
it does it at slow speeds too.. i dont know if i've heard the pop sound.. if it is the strut bearin around how much am i lookin at??
-tuna
Tuna is offline
Old 08-20-2004, 11:59 PM
Hooooooonda.....
DAVE Sz's Avatar
$30 and a few hours of your time.
DAVE Sz is offline
Old 08-21-2004, 06:26 AM
njmaxseltd's Avatar
The strut mount bearing doesn't cause a creaking sound, but more of a poping sound.
Creaking noises come from the sub frame and lower areas of the suspension. In some cases just going over all the sub frame and control arm bolts with a powerfull impact gun will cure them. You can check other areas like the rack and pinion mounts and all your ball joints and even the brake caliper and mounts (if it's happening while your foot is on the brake as well).
njmaxseltd is offline
Old 08-21-2004, 09:06 AM
ben99sel's Avatar
I sometimes get a creaking coming from my trunk area...but that is only after I installed the Stillen rear strut brace. I always figured it was the body of the car not being able to flex as much.
ben99sel is offline
Old 08-21-2004, 09:12 AM
datguyclark's Avatar
like njmax said...check your rack and pinion
datguyclark is offline
Miket2006
03-01-2021 03:55 AM
AaronL
08-08-2020 10:31 AM
Mahmuth
10-17-2015 12:03 PM
Need help
23
10-02-2015 08:56 AM
DC_Juggernaut
09-28-2015 04:07 PM
Quick Reply: creaking sound when turning-- help!!
