This forum is the Greatest - 99 KS changed
Old 08-19-2004, 07:42 AM
Pearl99GXE's Avatar
Thank you every one who posted the how tos. I finally changed my KS. I have a 99 Cali Spec, so it was not that easy with the swish valve in the way.
Getting it off was the easy part. Remove airbox assembly. Got the 12mm flex along with the 14in extension. Closed one eye to get a better view. Fished the socket over the bolt, try to turn it, nothing then, snap, the bolt broke free. Pulled out the bolt with an extension magnet. Pulll the sensor out using the wire attached to it. 15 minutes to get it out.
Now the hard part, Putting the new one back in there. Best advice received from others: Put some tape on the bolt, so it fits tightly in the socket. Attached the new sensor to the cable, use to magnet to fish it back in and to bring it in to position, so you can put the bolt back into it. With the socket extension in one hand and magnet in other, try find the hole. Can't do it, get frustrated, put it down, change fuel filter, PCV valve. Came back to it. With my magnet and socket extion fist the bolt back to the hole, felt a snag, start turning bolt. It is getting tight, WHOA HOO, I DID IT. SATISFACTION! Do the happy dance. Put the air box back on. Reset the codes. Go for a test drive. Fall in love again with your MAXIMA. Get back home, check for codes. Nothing. Go home and have a few beers, your job is done.
Thanks to this board, I have saved a lot of money. It was my pleasure to donate money to get this board up and running again.
Pearl99GXE is offline
Old 08-19-2004, 10:22 AM
Chassis Freak
VQuick's Avatar
That's why the Org exists. Knowledge is power, and knowledge shouldn't cost more than the effort you put into learning it.
VQuick is offline
RinconI30
11-10-2015 10:55 PM
NissanNismoZ
09-12-2015 07:30 AM
boomerbrian
09-04-2015 08:25 AM
crazyespn
09-03-2015 01:30 PM
Quick Reply: This forum is the Greatest - 99 KS changed
