Vacum Sensor Problem, PLEASE HELP!
Hella internets
Alright, i was replacing the vacum lines and one of the only vacum hoses that are connected to a sensor with plastic hose connectors, i snapped off...
I can take pics if someone can host it...
But i did get these #s off of the part, along with everything else on the side (in the following order):
Nissan (says on top)
some kinda mitsubishi sign, then: k5t46582
under that has this #:5206
its got a metal elbow for a vacum line at the top. and then 2 lower inputs for vacum lines at the bottome (made of plastic) the bottom one is the one that snapped off...
on the very bottom it has a female conector that plugs in to something (im assuming its a sensor of some sort?)
Hella internets
I found the part. And i think its the MAP/BARO Switch solenoid valve.
what does this do? anyone?
this is a link to the EGR system that has the pic of what i broke, its under the EVAP canister purge control SOLENOID valve. there are 2 one thats the solenoid valve and one that is just the EVAP purge valve.
http://img52.photobucket.com/albums/...ent=vacuum.jpg
EVAP canister purge control solenoid valve
Ive got the same thing right in front of me. I have a shop manual and it tells me that its EVAP canister purge control solenoid valve k5t46582. mines broken and its been a real hassle trying to find a new one. good luck though, if you can find some somewhere email me where at rconway91@gmail.com. its right next to the MAP/BARO.
Does it look like this, but black?
http://www.google.com/imgres?imgurl=...1t:429,r:7,s:0
lol wow that's a long *** link
ballerchris510
09-23-2015 08:46 PM
