Beep when lights left on, gone?
Hello All,
I have a question, does anyones Maxima beep when the lights are left on? My brothers 95 Max SE (auto) , beeps when the lights are left on, but my 96 SE (5 Speed) doesnt beep. Did the just have this beep on the 95s, or is there something I would need to change/fix to get the beep again, ofcouse I wouldnt have to worry as much cause I could pop the clutch if my lights every drainned my battery, but naturally it would be better to avoid having to do this all together.
thanks all.
thanks all.
check under the panel above your knees. there should be 2 screws holding it up. remove those 2 screws and see if the buzzer is plugged in. that's what makes the beeping noise when you forget to do something like turn off your headlights or remove your key.
I checked under my brothers 95, and heard the beeping but couldnt tell where it was comming from,
does anyone have a pic or a definate way I can locate the buzzer, I hope my didnt die, but now that I think about it I've never heard it since I've gotten the car (6 months ago), I check all my fuses and there fine and in good shape.
Maybe I need a new buzzer?
thanks
Originally Posted by R5a7B
If you remove the plastic sheild below the steering wheel, the buzzer will be connected to it with a wire connected, if it is connected. It's a little tanish colored box. All you have to do to remove it is unscrew the 3(?) screws holding.
I looked into changing the beep, and there are a few snags:
1. The relay that is connected times in and out, causing the momentary beep. If you add something else (say a song), you will get about .9 seconds of the song before it will start over. This will continually happen.
2. See number one.
I thought it would be cool to have a different beep, and any beep can be retrofitted. Just find the chime you want at a salvage yard (you could maybe even get one from Mercedes or BMW parts). It's twelve volts, momentary on and off.
2. See number one.
thanks
No problem, I can take pics for you tomorrow if you need them.
I would greatly appreciate if you could get some photos, thank you very much.
thanks
Here they are, hope this helps.
I can take a few more for you if you need them.
Thank you soo very much, I see what it looks like and where it is. Thanks for th help. Ihope its just unplugged if not, I'll add that to the list when I go to the junk yard.
dvcamp
09-18-2015 10:17 AM
markevans999
09-10-2015 04:29 PM
Maxima30
09-07-2015 06:13 PM
