anyone actuallu know
just wondering if anyone here knows anything about the air conditioning system in the maxima. mine stopped working. i just charged the coolant and checked fuses and relays. rpms do jump when i hit the AC bottom. I bought a 98 compressor but i'm not sure if it will fit in my 95 max or if that is even the problem. anyway, only repsond if u know wut ur talking about. thx i'm trying to pin point the cause of the problem
do you know how to check if the compressor is working?the way i did was as your lookin at your engine, to the top left there is a 'plug in' ( follow your ac line to make sure).. but its at the top, top left. pull the plug out, the part you pull out has two little holes- thats cause it "plugs into", just take a wire and put each end in each little hole and if you hear your rpms idle, your compressor is good. i just did this a few days ago and its very easy and it wont hurt your car, so....
Ac Sux
i'm not sure what you mean? take the wire plug out and short it. can u be more clear please. anyone else have any knowledge.
SurraTT
07-09-2005 11:50 AM
