how do you test ignition coils and injectors using a multimeter?
Old 06-12-2004, 01:08 AM
michaelnyden's Avatar
what do you have to test and what reading should I get testing a coil and injector? the chilton is unclear here....
michaelnyden is offline
Old 06-12-2004, 04:01 AM
Kevlo for President
Kevlo911's Avatar
To Test Ignition Coils:
With the ignition off, disconnect the electrical connector from the ignition coil. Connect the positive (+) probe of an ohmmeter to terminal no. 1 and the negative (-) probe to terminal no. 2 of the coil connector - the meter should indicate infinite resistance. Reverse the meter leads ( negative probe to terminal no. 1 and positive probe to terminal no.2) - the continuity should be indicated, but not zero ohms. If the results are not as specified, replace the coil.
Connect an ohmmeter between the secondary terminal ( the one that the spark plug connects to) and terminal no. 1 - the meter should indicate infinite resistance. If not, replace the coil.
Note - Ohm meter to test coils is not the most reliable way. Some peoples’ coils tested perfectly, but they still misfired.
Kevlo911 is offline
Old 06-13-2004, 01:33 AM
i placed the positive lead against pin 1 and the negative lead against pin 2 and put my multimeter into ohm/resistance mode....in one range setting, I got 1.5-1.6 across all the coils and then I switched range settings and got something like 0.5 across the coils
Old 06-13-2004, 01:42 AM
don't know what any of this means though...
Old 06-13-2004, 09:39 AM
bump bump bump
Old 06-14-2004, 05:59 AM
slfalco's Avatar
If you have intermittent misfires, an ohmmeter test is useless. As these coils weaken, they may misfire only under operating conditions... I had intermittent misfires that set the CEL but would not indicate which cylinder.. ended up replacing all 6 coils..
slfalco is offline
jmlee44
10-02-2022 02:13 PM
tarun900
19
12-20-2021 06:57 PM
aw11power
10-10-2021 04:57 AM
AaronL
08-08-2020 10:31 AM
zmcneely13
09-26-2015 02:26 PM
Quick Reply: how do you test ignition coils and injectors using a multimeter?
