LED Dome light not working right
Just put in a 4 blue led which looks great except for the fact that unless I have the switch set to off it stays on, regardless of the door being open or closed.
I also replaced the step lights with led's but they turn off when the door is closed.
try switching it around? maybe the switch that decides whether it's on door, on, or off is broken? take it all apart, play with it and then try it again. usually works for me when stuff like that goes wrong. goodluck
i thought about buying that led, where'd you get it? www.superbrightleds.com?
The bulb only goes in one way and there is no problem with the switch, the regular incadescent bulb works fine. I know that using led's for turn signals speeds them up unless you add a resistor so...
carguy96
20
02-06-2021 06:21 AM
vingodine
45
05-21-2016 12:46 PM
King_Ten_Ahead
09-30-2015 04:27 PM
jerrod99_se-l
08-27-2015 08:27 PM
