over heating
Old 04-03-2004, 08:05 AM
xedap1998's Avatar
over heating
My 95 maxima auto is overheating (3/4 way up the temp gauge) Please help. I have replaced the thermostat this past winter maybe that is the reason?? I am unable to perform search on this topic...
xedap1998 is offline
Old 04-03-2004, 08:37 AM
A5295's Avatar
is doing it every time you drive it? Have you flushed the cooling system? have you checked your coolant level? Is it leaking or burning coolant? Is the car driving ok? Have you noticed a loss of power? do your cooling fans turn on? does it do it sitting still, or more so when on the road?
hate to ask a bunch of questions, but the best way to find out the resolution of your issue is to get specific with the description of your problem.
A5295 is offline
Old 04-03-2004, 09:41 AM
Jatan's Avatar
According to Haynes manual:
OVERHEATING
1. In sufficient coolant in system
2. Water pump drivebelt defective or out of adjustment
3. Radiator core blocked or grille restricted
4. Thermostat faulty
5. Electric coolant fan inoperative or blades broken
6. Radiator cap not maintaining proper pressure
7. Ignition timing incorrect
Check for a coolant leak. Maybe it's the water pump
Jatan is offline
tarun900
19
12-20-2021 06:57 PM
Fbana41
08-29-2016 12:18 PM
captchaos
03-15-2016 12:18 PM
Derrick2k2SE
11-19-2015 10:14 PM
Max Nu-BE
09-28-2015 10:25 AM
Quick Reply: over heating
