wheels squeaking. BRAKE PAD worn?
Old 03-29-2004, 08:55 AM
iregula's Avatar
My wheels squeal when they are rolling, and my brakes seem a little weak. does anyone know if the indicator for worn brakes intentionally makes that sound? if so, what is the best brake pad replacement solution? thanks
iregula is offline
Old 03-29-2004, 11:10 AM
PLUMMAXSE's Avatar
Sounds like you need pads and rotors. The only real way to tell is to inspect the rotors with the wheels off. If you can snag your fingernail dragging over the rotor, that means your pads have hit the rotors.
PLUMMAXSE is offline
Old 03-29-2004, 12:15 PM
wariow's Avatar
brake squeekage doesn't necessarily mean worn pads. It's probably the piston or the top and bottom sides of the pads that are rubbing against the the brake pad bracket. Take off the wheel, and look over the rotor and see how much meat the pad has left. if it's more than 2mm around, then it's good, just take out the pads and lube up the sides of the pads and relube the piston sides also and put it back in. It shoulld help eliminate squeekage.
wariow is offline
Old 03-29-2004, 01:42 PM
Brudaddy's Avatar
I second that about it not necessarily being the need of new pads/rotors. Sometimes, even when you get new ones, they squeak.
Brudaddy is offline
Old 03-29-2004, 02:01 PM
99maxx-on19's's Avatar
skrew that!i have a problem my ride makes a killer noise like a hard thumping sound when i let off the gas but i step on the gas it goes away my.Hole front end makes noise and it bothers the crap out of me
99maxx-on19's is offline
Old 03-29-2004, 02:18 PM
s0ber's Avatar
Broken strut mounts?
s0ber is offline
BkGreen97
04-02-2016 05:47 AM
bbsitum
09-11-2015 04:55 PM
dcam0326
09-08-2015 11:02 PM
A32goldylocks
09-02-2015 06:39 AM
Quick Reply: wheels squeaking. BRAKE PAD worn?
