Blue smoke coming out of the exhuast?
You are deffinity burning oil... Do a compression check on each cylinder to see if your within spec's.
If your compression turns out to be ok. Then it is probably a bad spark plug tube seal on the underside of your valve cover. These are round rubber gaskets. If these are bad then you could probably be leaking oil through where the spark plugs tread in. Thus fouling your spark plugs & causing your vehicle to ping.........
Originally Posted by LudeAEM
as others have said... blue smoke = oil
Originally Posted by mansurxk
while were ont he same topic, im wondering if that Alemite CD-2 actually helps slow down or prevent the blow-by, ive read stuff bout it on the net, but no concrete evidence ( i havnet searched vigorously)
