Can I trust eBay's FSTB?
Old 02-22-2004, 01:32 PM
1NICEMAX's Avatar
I know a strut bar is a strut bar, but I think that eBay ones look very cheap. Is there anyone on the .org that sells them for a reasonable price, or should I trust eBay?
1NICEMAX is offline
Old 02-22-2004, 01:33 PM
ILoveMyMax's Avatar
they work great i got mine for 20 shipped
ILoveMyMax is offline
Old 02-22-2004, 01:37 PM
Cheesing away...
KsuMax's Avatar
Agreed. Mine still works fine and it's been on for a year. I never saw a point in buying an expensive one.
KsuMax is offline
Old 02-22-2004, 01:42 PM
96white's Avatar
mine works well
96white is offline
Old 02-22-2004, 01:51 PM
V^___^V
happyricefob's Avatar
sure why not?
happyricefob is offline
Old 02-22-2004, 07:36 PM
will fly for food
Maxima99SE's Avatar
ive had mine for about a year... with no problems at all
Maxima99SE is offline
Old 02-22-2004, 07:45 PM
Give me a Bud Light Holmes
sagamax's Avatar
i got a good deal on ebay. i happy wit my ebay fstb
sagamax is offline
Old 02-22-2004, 10:51 PM
Silvia's Avatar
does FSTB makes diffrence at all??? i had one before on previous car (below on my signature) but hmm couldnt feel any diffrence/....
Silvia is offline
Old 02-22-2004, 10:57 PM
mansurxk's Avatar
made a heck of a difference on mine, installed it 2 nights ago, i can whip the heck out of it now, quick turns with MUCH less body roll, i twas the ebay FSTB isntalled it on my 95 GLE, no fitment issues from seller Evovector, i initially thought i twas in my head, but i tested it out on onramps on S curves and it i dindt get pushed into my seat like i usually do. then had my friend testdrive it because he claimed it had much more body roll than his 3.2TL type S, he was pretty amazed that a $20 bar made so much difference in handling. i give it
mansurxk is offline
Old 02-23-2004, 07:23 AM
Imobejoas's Avatar
I think I'm going to say... YMMV. Normal street driving you will notice a slight difference ONLY on tight turns. Slightly less body roll. Rainy days, your car dramatically handles different. Only way to really see if it works is to go do autox which I haven't tried.
If you want a cheap/cosmetic solution the ebay bar is not a bad investment. I think the more expensive ones should be sturdier and thereby making it even better. But hey... it's just a bar
Imobejoas is offline
Old 02-23-2004, 01:03 PM
Brudaddy's Avatar
First of all, the ebay ones are fine. I got mine for like $16.50 from Revotec.
Second, they don't make a really huge difference. They do, however, change it a little.
Third, they don't correct body roll fellas! What the FSTB does is stop the struts from traveling in any direction other than up and down to absorb bumps. This just steadies the front end...which helps in our maximas that seek side to side while turning at WOT. It doesn't help body roll.....that is a rear sway bar. It just keeps the struts from going side to side(thus the name).
Brudaddy is offline
Old 02-23-2004, 02:12 PM
Always sunny in philly
Nismotic's Avatar
my very first mod: ebay strut bar. I've felt a difference; never knew why ppl liked spending 200+ for a little bar...
I actually replaced my strut bar with a midget inside.
Nismotic is offline
Old 02-23-2004, 02:19 PM
I need a truck
Conrad283's Avatar
I have the ebay one. Total goodness
Conrad283 is offline
Old 02-23-2004, 02:57 PM
Brudaddy's Avatar
cool, a midget...where can I get one of those...ha ha
Brudaddy is offline
Old 02-23-2004, 05:32 PM
drew76924's Avatar
yes i have 1 and i love it it works jus as good as all the others
drew76924 is offline
Old 02-24-2004, 12:54 PM
Brudaddy's Avatar
the midget or the bar, cause I am getting confused
Brudaddy is offline
Old 02-24-2004, 01:25 PM
I'm nutty for Nissans
JSutter's Avatar
All the eBay bars I have gotten work fine.
JSutter is offline
Old 02-24-2004, 01:44 PM
TMaxx's Avatar
I never used a strut bar, are they easy to install or do I need to take it to a shop?
TMaxx
TMaxx is offline
Old 02-24-2004, 03:39 PM
Ute
Ute's Avatar
TMaxx
Can you change a tire? If so, you can install a FSTB. Same level of difficulity. A torque wrench is nice, but not necessary.
Ute is offline
Old 02-24-2004, 03:43 PM
mansurxk's Avatar
why is a torque wrench not necessary?aren't the bolts in danger of ripping if you dont apply the correct torque of 30 ft lbs? id just go with the torque wrench, autozone lets you rent it out for free just leave a deposit, so id just go with that to be ont he safe side
mansurxk is offline
Old 02-24-2004, 05:08 PM
Rooster286's Avatar
FSTB is just a chunk of metal, no matter how you look at it. Cattmans "titanium" FSTB is nothing more than eye candy compared to what you can get on Ebay. As long as the bar is sturdy (and they all seem to be) it doesn't matter which one you get, unless you have a show car, or need the satisfaction of knowing you have a "cool" looking FSTB under your hood.
Rooster286 is offline
Old 02-25-2004, 08:41 AM
Brudaddy's Avatar
Maxima10to1, how many strut bars have you put in there? ha ha. I thought we only needed one...j/k
Brudaddy is offline
Old 02-26-2004, 12:50 PM
Ute
Ute's Avatar
Your suppose to torque your lug nuts to a specified amount also, but that rarely happens outside a shop. You can feel the tension if you are good, within a few ft lbs. Like I said, a torque wrench is nice but not necessary. As long as you don't force it or have a 450 lb bench press, it'll work.
Ute is offline
Old 02-26-2004, 01:47 PM
Brudaddy's Avatar
be careful not to get a wrench that is too long. It is really easy to exert too much torque with a long wrench. I mean, that is how a torque wrench works so easily............it is long. You don't even have to pull all that hard because you have all that torque.
Brudaddy is offline
Old 02-26-2004, 01:50 PM
Well I should wrap this up before I start to ramble.
CystumMax's Avatar
I have mine from ebay, its not that bad. I don't think you should spend 180 bucks on FSTB. So i went with this one on ebay.
Shipped for 28 bucks.
CystumMax is offline
litch
123
01-04-2024 07:01 PM
04-16-2020 05:15 AM
220k+ A32
25
10-03-2015 09:09 PM
Socalstillen
09-26-2015 12:01 PM
Quick Reply: Can I trust eBay's FSTB?
