Took my seats out and WTH
Old 03-10-2001, 03:36 PM
DARTHSWAN's Avatar
I was relaying my rca cords and when I went to take my seat out, there was a wire under there. Does anyone know what that is? Could that be a heated seat hook up up wire? If so I'm going to get one and put it in before I get my leather. I have a GXE. Thanks
Kevin
DARTHSWAN is offline
Old 03-10-2001, 04:56 PM
Daniel B. Martin's Avatar
More information, please
Kevin
More details would be helpful. A wire? Probably more than one. Did they terminate in a connector? How many terminals? What color plastic? What color wires?
What you found could be a seat heater supply. It could also be a "this seat occupied" switch.
Daniel B. Martin is offline
Old 03-10-2001, 06:59 PM
CKNY's Avatar
drivers seat has a few wires. one (green if i remember correctly) is for the seatbelt warning. the others are for the power seat/heated seat hookup in the se/gle's
CKNY is offline
Old 03-10-2001, 08:23 PM
WaarrEagle's Avatar
So if this wire is for heated seats and I have it what would be involved in getting them? Completly new seats or what?
WaarrEagle is offline
Old 03-10-2001, 09:54 PM
danny's_max's Avatar
Which seat did you find it under? Do you have powered drivers seat? I have a GXE also with powered driver seat and under the passenger seat, theres also a wire, I'm pretty sure that its a pre-wired for powered seats, like on the GLE.
danny's_max is offline
Old 03-11-2001, 07:39 AM
DARTHSWAN's Avatar
Okay, I looked under the passanger seat. It is 2 wires tied together. black and yellow. They run into a white connector.
Old 03-11-2001, 08:01 AM
plrod Black 95 SE's Avatar
You might be in luck: I have a wire in my hand which came off the passenger seat on a 97 with leather. I bought these and am trying to install them in my 95 SE but can't find the wire you are referring to in my car. One wire is yellow with a black line, the other is black with silver circles about 1mm wide about every inch and leading to a white connector which has the black one in a vertical position and the yellow one horizontally. Man I'm looking for this wire and cannot find it in my car. I posted and sinewave indicated that my car may not have had the power passenger seat option available, but the FSM shows that I should have this wire and I've looked even under the console and cannot find it.
Where specifically did you find this?
plrod Black 95 SE is offline
Old 03-11-2001, 08:07 AM
DARTHSWAN's Avatar
I found that wire hooked up to my seat, under the seat. Is that the wire for power seats? If so how do I go about getting the motor for it? Or, is that the wire for heated seats? The wire is just sitting there.
Old 03-11-2001, 08:15 AM
That is the wire for power seats, which I'm trying to install. What year is your car and what trim level?
Old 03-11-2001, 08:18 AM
check out my thead:
https://maxima.org/forums/showthread...threadid=26831
DARTHSWAN's Avatar
I have a 99 gxe. base. bought it that way on purpose.
Old 03-11-2001, 09:31 AM
RussMaxManiac
I had a SE with cloth, one power seat driverside. I switched it over to leather and the passenger went to power, that actually is for power seats......
Old 03-11-2001, 10:03 AM
You have identified electrical connector B6, located under the driver's seat. It has two wires:
- black (ground)
- yellow with black tracer (power)
This is the connector for the driver's side power seat.
sliptap
09-30-2015 05:57 AM
uttadms31
09-30-2015 05:24 AM
salty318
09-29-2015 01:21 PM
salty318
09-28-2015 07:22 PM
2kmaximel
09-24-2015 03:55 PM
Quick Reply: Took my seats out and WTH
