Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 01-27-2004, 12:05 AM   #1
Timing Cover gaskets.
I think I have a leak behind my timing cover gasket. This royally sucks ****. I lose about a 1/4 of a quart of oil every 3 - 4 weeks. I've already replaced two valve cover gaskets and seals and oil pressure sending unit. Doing those two things has substantially decreased my oil leaks, but need to tackle the last one (before I'd lose 1/4 quart every 1-2 weeks). I have a 95 auto with 233K miles.
I was wondering...what gaskets should I replace if I were to replace anything behind that timing cover? I understand, that between the two-piece timing cover seam, you should use permatex RTV sealant...but what type (black, grey)? I also think there are 2 caps on the front of the engine block that are behind the timing cover. What are those part numbers?
Does anyone have the OEM part numbers for any and all gaskets/seals that need to be replaced if I take off the entire timing cover (including crank and cam sprockets...chains...etc.)? I'm going to leave all the timing chains alone (not replace them)...as well as the waterpump...I just don't want to spend the money right now.
Does anyone have all applicable OEM part #'s for this type of job? Secondly...which I'm considering...should I just swap the engine for a used....and seal up the old one? The seal job looks d amn hard doing it while the engine is still mounted in the car.
I think I'm looking at either : $50-$100 for new gaskets and seals and 15-20 hours of labor (for just a seal job) OR: $600 for a used engine and swap, including rear main seal..and 15-20 hours worth of labor. Tho of course with a spare engine...I could play with it (new cams...etc etc.) and it be more stress-free.
Please help! -Isaac
izzydig is offline   Reply With Quote
Old 01-27-2004, 05:56 AM   #2
ejj
Send a message via AIM to ejj
All the seals that I can recall with the timing cover are RTV grey. I don't know what you're refereing to with the "2 caps on the front of the engine block that are behind the timing cover."
I took my old engine apart (pics), but it was out of the car after doing a swap. Doing this with the engine in the car would be tough, but not impossiable.
__________________
99 SE, V2 w/3.125" pully, engine #2
ejj is offline   Reply With Quote
Old 01-27-2004, 06:08 AM   #3
Points: 7,044, Level: 55
Points: 7,044, Level: 55 Points: 7,044, Level: 55 Points: 7,044, Level: 55
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Yeah, I also need to do this. I think you have to support the engine from a above because you have to remove 3 of the 4 engine mounts (says haynes) and drop the oil pan(s) before you remove the front timing cover.
Anyone done this fix themselves? We need input.
big_al is offline   Reply With Quote
Old 01-27-2004, 09:35 AM   #4
Dreizehn's Avatar
Send a message via AIM to Dreizehn Send a message via Yahoo to Dreizehn
Quote:
I think he is referring to the water pump cover and the chain tensioner cover...
__________________
Dreizehn is offline   Reply With Quote
Old 01-27-2004, 09:59 AM   #5
ejj
Quote:
That's what I thought...but the bit about being "behind" the timing chain cover confused me.
Old 01-27-2004, 08:36 PM   #6
From looking at the haynes book...I remember there are two caps that are on the block itself (not the water pump and tensioner cover plates). You'd have to remove the entire timing cover (front and back) to see them. I believe another member confirmed this, but I don't know what the part no's are. Maybe they are non-existant? Anyone have a FSM? If they are non-existant...I'd be very happy. I remember another guy had done just about everything to fix a similiar type of leak, except those two caps.
I'm building a list of things to do a complete job. Tell me what you think. I may just have to head over to the dealership...and look through their computer to see what I need. Did I miss anything? Thanks.
Option A:
http://www.nissan-part-dealer.com:
Front oil pan gasket. $6.11
Rear oil pan gasket. $6.11 (Note: Is the front and rear for the upper oil pan?)
Crankshaft front seal. $4.82
http://www.partsamerica.com (checker, kragen)
Fel Pro OS30696 - Lower Oil Pan Kit. $10.99
1 Permatex Black High Temp RTV. $3
2 Permatex Grey RTV. $6
Option B:
Fel Pro OS30696 - Upper Oil Pan Kit. $13.99
Beck/Arnley 0523741 - Front Crank Seal. $4.99
Old 01-28-2004, 05:41 AM   #7
ejj
Quote:
Here's a pic of the block with no timing covers:
Click the image to open in full size.
I don't see any "covers".
Old 01-28-2004, 06:53 AM   #8
Dreizehn's Avatar
Agreed...
I'm not sure what he's referring to...
Here is another pic in case you wanted a second opinion.
Old 01-28-2004, 12:03 PM   #9
What are these things shown as A and B on the pic?
A don't look like caps, but I think those are things I was thinking about (and look replaceable). B looks like caps of some sort, but originally weren't what I was thinking about. Great Pics BTW. Thanks.
Old 01-28-2004, 12:17 PM   #10
Dreizehn's Avatar
The Red things refered to as "A" are o-rings. Thats the path of the oil from the pump through the chain cover and into the block.
What B refers to I never noticed. I think it's part of the casting of the head but without looking at it closer I'm not sure.
Old 01-28-2004, 12:27 PM   #11
ejj
My first thought was that they could be drilled out for coolant passages....althought its obvious Nissan didn't intend that in our application.
Old 01-28-2004, 12:42 PM   #12
Dreizehn's Avatar
Freeze plugs?
Old 01-28-2004, 12:45 PM   #13
ejj
Freeze plugs?
Ah! I bettcha you're right. I've got the old heads laying around my garage...I'll take a look tonight.
Old 01-28-2004, 12:48 PM   #14
Dreizehn's Avatar
I bet that's what they are. Unless they leak nobody really pays much attention I guess.
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
