Timing Cover gaskets.
Old 01-27-2004, 12:05 AM
izzydig's Avatar
I think I have a leak behind my timing cover gasket. This royally sucks ****. I lose about a 1/4 of a quart of oil every 3 - 4 weeks. I've already replaced two valve cover gaskets and seals and oil pressure sending unit. Doing those two things has substantially decreased my oil leaks, but need to tackle the last one (before I'd lose 1/4 quart every 1-2 weeks). I have a 95 auto with 233K miles.
I was wondering...what gaskets should I replace if I were to replace anything behind that timing cover? I understand, that between the two-piece timing cover seam, you should use permatex RTV sealant...but what type (black, grey)? I also think there are 2 caps on the front of the engine block that are behind the timing cover. What are those part numbers?
Does anyone have the OEM part numbers for any and all gaskets/seals that need to be replaced if I take off the entire timing cover (including crank and cam sprockets...chains...etc.)? I'm going to leave all the timing chains alone (not replace them)...as well as the waterpump...I just don't want to spend the money right now.
Does anyone have all applicable OEM part #'s for this type of job? Secondly...which I'm considering...should I just swap the engine for a used....and seal up the old one? The seal job looks d amn hard doing it while the engine is still mounted in the car.
I think I'm looking at either : $50-$100 for new gaskets and seals and 15-20 hours of labor (for just a seal job) OR: $600 for a used engine and swap, including rear main seal..and 15-20 hours worth of labor. Tho of course with a spare engine...I could play with it (new cams...etc etc.) and it be more stress-free.
Please help! -Isaac
izzydig is offline
Old 01-27-2004, 05:56 AM
ejj
ejj's Avatar
All the seals that I can recall with the timing cover are RTV grey. I don't know what you're refereing to with the "2 caps on the front of the engine block that are behind the timing cover."
I took my old engine apart (pics), but it was out of the car after doing a swap. Doing this with the engine in the car would be tough, but not impossiable.
ejj is offline
Old 01-27-2004, 06:08 AM
big_al's Avatar
Yeah, I also need to do this. I think you have to support the engine from a above because you have to remove 3 of the 4 engine mounts (says haynes) and drop the oil pan(s) before you remove the front timing cover.
Anyone done this fix themselves? We need input.
big_al is offline
Old 01-27-2004, 09:35 AM
Dreizehn's Avatar
I think he is referring to the water pump cover and the chain tensioner cover...
Dreizehn is offline
Old 01-27-2004, 09:59 AM
ejj
ejj's Avatar
That's what I thought...but the bit about being "behind" the timing chain cover confused me.
ejj is offline
Old 01-27-2004, 08:36 PM
izzydig's Avatar
From looking at the haynes book...I remember there are two caps that are on the block itself (not the water pump and tensioner cover plates). You'd have to remove the entire timing cover (front and back) to see them. I believe another member confirmed this, but I don't know what the part no's are. Maybe they are non-existant? Anyone have a FSM? If they are non-existant...I'd be very happy. I remember another guy had done just about everything to fix a similiar type of leak, except those two caps.
I'm building a list of things to do a complete job. Tell me what you think. I may just have to head over to the dealership...and look through their computer to see what I need. Did I miss anything? Thanks.
Option A:
http://www.nissan-part-dealer.com:
Front oil pan gasket. $6.11
Rear oil pan gasket. $6.11 (Note: Is the front and rear for the upper oil pan?)
Crankshaft front seal. $4.82
http://www.partsamerica.com (checker, kragen)
Fel Pro OS30696 - Lower Oil Pan Kit. $10.99
1 Permatex Black High Temp RTV. $3
2 Permatex Grey RTV. $6
Option B:
Fel Pro OS30696 - Upper Oil Pan Kit. $13.99
Beck/Arnley 0523741 - Front Crank Seal. $4.99
izzydig is offline
Old 01-28-2004, 05:41 AM
ejj
ejj's Avatar
Here's a pic of the block with no timing covers:
I don't see any "covers".
ejj is offline
Old 01-28-2004, 06:53 AM
Dreizehn's Avatar
Agreed...
I'm not sure what he's referring to...
Here is another pic in case you wanted a second opinion.
Dreizehn is offline
Old 01-28-2004, 12:03 PM
izzydig's Avatar
What are these things shown as A and B on the pic?
A don't look like caps, but I think those are things I was thinking about (and look replaceable). B looks like caps of some sort, but originally weren't what I was thinking about. Great Pics BTW. Thanks.
izzydig is offline
Old 01-28-2004, 12:17 PM
Dreizehn's Avatar
The Red things refered to as "A" are o-rings. Thats the path of the oil from the pump through the chain cover and into the block.
What B refers to I never noticed. I think it's part of the casting of the head but without looking at it closer I'm not sure.
Dreizehn is offline
Old 01-28-2004, 12:27 PM
ejj
ejj's Avatar
My first thought was that they could be drilled out for coolant passages....althought its obvious Nissan didn't intend that in our application.
ejj is offline
Old 01-28-2004, 12:42 PM
Dreizehn's Avatar
Freeze plugs?
Dreizehn is offline
Old 01-28-2004, 12:45 PM
ejj
ejj's Avatar
Freeze plugs?
Ah! I bettcha you're right. I've got the old heads laying around my garage...I'll take a look tonight.
ejj is offline
Old 01-28-2004, 12:48 PM
Dreizehn's Avatar
I bet that's what they are. Unless they leak nobody really pays much attention I guess.
Dreizehn is offline
Matt93SE
05-24-2019 02:58 PM
Matt93SE
04-08-2018 09:23 AM
maxprivate
Forced Induction
21
07-08-2017 09:48 AM
iflexsteel
09-15-2015 03:37 AM
MaximaDrvr
08-19-2015 08:20 PM
Quick Reply: Timing Cover gaskets.
