Transmission sensor cracked.. how bad is that?
When I was changing CV axles 2 weeks ago, I was checking tranny (5sp) for leaks and found that transmission sensor is cracked in the spot where it's being held with a bolt. So now it is not held with a bolt obviously at all, but I did not see it leaking. However I am getting more concerned that it may fall out on one nasty bump and ruin transmission, which will be left without oil.
Here is the pic with a spot marked where it's cracked. (Borrowed from StygianMax's Nissan: 'DigiMax' page).
Originally Posted by PedalKick
Put a large washer under the bolt to overlap the
other part of the sensor
You should be fine. mine had been cracked for ages. Just look occasionally to see if it moved, it shoudlnt, It takes a small hammer to pop it out from the inside, so i doubt it would fall out.
sctludwig
09-01-2022 01:32 PM
boomerbrian
10-31-2018 10:25 AM
