EVAP canister purge volume control valve??
#42
Jteer1971...pull the connector plug from your ECPVC as shown in the great pics above and check the pins ON THE VALVE as suggested using an ohm-meter. I imagine you'll find that it's faulty considering the code you have.
Shell...where did you end up buying one instead of the Stealership?
#43
Originally Posted by sterling99SEL
Just after replacing my knock sensor, I'm getting these three EVAP-related codes:
Is it likely I could have damaged my EVAP control valve or knocked a harness loose possibly?
#45
Bumping a 2 year old thread for not reading, and after you already got your answer in the newbie thread
#47
the canister and the valve are too differnent things.
I had this issue and it was cuz the wire harness fo rthe valve was all corroded and and new wires needed to be connected.
I wd say these thing last forever. jus trace the wires to see if there is a short. Or check the FSM for troubelshooting
tseng1023
10-15-2015 08:30 AM
hayne
10-05-2015 11:53 AM
