What the F is in the A-pillar that rattles?
So there is something at rattles and makes noise in the A-pillar, is there a wire harness that gets loose?
How hard is it to take off the pillar cover and fasten whatever is back there?
I stuffed old rags in there. I tore small pieces off and pushed them in with a panel removal tool, I used a butter knife once. Worked for me A pillars are nice and quiet now, no matter how hard I take a corner.
I get the rattle in the A-pillar too but can only hear it over rough roads. The bigger problem for me is some loose bolt or something in both my front doors. Sounds like a loose screw or metallic object that vibrates everytime i blast the stereo or when i drive over bumps. I'm pretty sure others experience this as well. My friend's max does this too.
For the doors use Dynamat Extreme. For the A pillars use rags, trust me it works. The pillars on my Max are nice and tight now. I had over 1,000 watts RMS of amplifier power and the rattles drove me nuts(700 of those watts were for my sub), so I used Dynamat in the front doors and trunk, and rags in odd places, like the A pillars. The A pillars would make noises when I made sharp turns as well as when the music was on loud, not anymore though.
Now I just have to figure out where I am getting some more squeaks since I lowered my car. I have two from the trunk area and I can't find thier origin.
it's the wires in there that are rattling. get some foam and stuff it between the wires and the a pillar (not the plastic cover).
Or just tape the wires down from top to bottom to the pillar.
I ran my radar detector line down that way and zip tied everything really taut. no rattling!
Jae
Jae
lrb6805
09-17-2015 04:49 PM
