o2 sensor right bank
AFR=air fuel ratio. Your right bank could be lean causing excessive heat, but you would have a lean code.
More likely that you are leaking oil from your valve cover onto the sensor and killing it.
I am not getting any codes other than 0503 for the o2 sensor. It comes out dry with no apparent oil residue on it. Is it possible the front bank o2 sensor has been neutralized to be unfunctional, in the ecu, somehow which presumably would cause an unbalance?
I have the same exact problem! I replaced that right bank o2 sensor and now several months later, the check engine light is back on with the 0503 code. I know how to reset the check engine light but after driving for about a minute, it comes back on with the same code. Im going to my buddy's shop to check it out. Maybe I'll replace it and see if it's better because I put a really cheap 02 sensor in there.
check all your fuses. there was just a thread recently where dude took his car to a nissan dealer for O2 codes and they replaced them only to find out it was a couple blown fuses throwing the codes. AFTER paying to replace the O2 sensors first of course.
Let us know what you find out.
jmlee44
10-02-2022 02:13 PM
my03maxima
04-29-2020 12:48 AM
hayne
10-05-2015 11:53 AM
