Please help me to open the foglight housing for a retro fit...
Old 09-17-2007, 11:07 AM
3 point slow's Avatar
I have these yellow bulb shells. The ones that the actual bulb goes into. I wanna do a retrofit kinda thing. I have the foglights removed from the car and I also have a heat gun. Ive pretty much destryed the one foglight trying to seperate the actual glass from the housing. Ive heated it a few times and scraped alot of glue out but this thing still wont seperate.
Does anybody have a very detailed and specific method of doing this??
3 point slow is offline
Old 09-17-2007, 11:51 AM
Sold
JSMax's Avatar
If I remember correctly, you need to use a dremel with a cutting wheel on the grey plastic. When you are ready to put them back together, you need some sorta cement. It comes in 2 parts and you mix them together. I can't remember the name of it right now, but I'm sure another member will chime in.
g/l
JSMax is offline
Old 09-17-2007, 12:58 PM
Ridin' Spinnaz
ZachsMax's Avatar
JB Weld?
10char
ZachsMax is offline
Old 09-17-2007, 01:47 PM
Former Vendor
BLACKonBLACK98's Avatar
panel bonding adhesive?
BLACKonBLACK98 is offline
Old 09-17-2007, 04:45 PM
Damn! lol. There I was with a stupid heat gun and a flat head screwdriver. Heat n chiseling out endless amounts of glue. I have this ridge running around the entire border of the lens but it still wont pop out. Guess I have to go charge my dremmel then. Grr...
This is frustrating.
Epoxy glue comes in 2 parts but I dunno if thats safe on plastic. Maybe some sort of silicone sealer? (for when I put it back together.)
Old 09-17-2007, 05:28 PM
goldtooth's Avatar
Plastic weld.
Or you can stick it in the oven like I did and carefully detach the glass from the housing, but be VERY CAREFUL because the glass is extra hot and the plastic house is very soft.... Im not exactly sure how long it needs to be in there for, check the how-to's, for taking apart your headlights, the approx. degrees and approx. timelenght are in there.
goldtooth is offline
Old 09-17-2007, 07:01 PM
Sold
JSMax's Avatar
yeah, JB Weld. that's what it was. Hope that helps. Post pics when your done.
good luck.
JSMax is offline
Old 09-17-2007, 07:51 PM
Ridin' Spinnaz
ZachsMax's Avatar
I'd recommend some kind of epoxy instead.. I dunno how well JB weld will hold up when not applied to metal. And some caulk or silicone sealant or something, of course.
ZachsMax is offline
Old 09-18-2007, 05:30 AM
The oven technique worked!!! Forget the heat gun. I seperated the glass. This is still gonna take me a while to figure out. Next problem is to somehow make the hole that the bulb casing poked through the reflective backing just a little bit bigger. Hopefully, Ill have a chance to mess with this some more tonight.
Old 09-18-2007, 09:09 AM
Sold
JSMax's Avatar
try a hole saw.
JSMax is offline
Old 09-18-2007, 09:14 AM
I never heard of a hole saw. Hmm...Imma look into it. It has to be something that wont crack the reflective plastic. This stuff is super fragile.
Old 09-18-2007, 09:35 AM
Ridin' Spinnaz
ZachsMax's Avatar
A hole saw would crack it. It's basically a circular piece of metal with teeth and a drill bit in the center. Plus, to use a hole saw properly you need to start drilling without a center hole (which already exists because the bulb sticks through it) so that the drill bit part of the hole saw will provide a pilot hole, keeping the hole saw from skipping and tearing up the material.
http://en.wikipedia.org/wiki/Hole_saw
You might be better off using some kind of rotary tool like a Dremel (with a very fine disc), but you're still risking some damage..
ZachsMax is offline
Old 09-18-2007, 10:40 AM
Thats some good info, right there! Thanks. Yea...I looked up a hole saw also. Maybe a fine sander attachment for my dremmel might do the trick. I have to see. The new bulb housing that Im using (yellow) fits. Its a matter of the metal that its attached to. I might modify the old piece and glue the new bulb housing to that. I have to look again.
Old 09-18-2007, 11:22 AM
goldtooth's Avatar
I have my reflectors from my fogs, if you need more.... I didnt reuse them and now they are useless to me
Old 09-18-2007, 11:28 AM
Great!! Now I can be a little more bold when butchering these. lol. Ill let you know as I progress. If I do end up destroying them, Ill gladly pay shipping to take them off your hands. Btw, what did you do to your fogs?
Old 09-18-2007, 11:40 AM
Notice the chopped up plastic because I was first using a heat gun and chiseling away with a flathead. lol. Thanks again for the oven technique.
Ill take more pics tonight. Its been disassembled even further.
Old 09-18-2007, 01:32 PM
goldtooth's Avatar
I put IS300 fog projectors in my housings.
Old 09-18-2007, 01:36 PM
Sweet!!! I dont even know what I have. lol. I bought it on a whim from the classifieds. All I know is that the bulb housing is yellow and the wires on the bulb itself is a tiny bit different. Ill show pics of exactly what I have tonight or tomorrow.
I bet the IS300 fogs look amazing!
Old 09-18-2007, 02:19 PM
goldtooth's Avatar
It would look better if the inside of the glass was smooth and clear and not wavy with those ridges.
Old 09-18-2007, 03:36 PM
I could be full of crap but I THINK those ridges help disipate the light. That way, they get a broader range beam pattern. Again...I THINK. lol. I agree, though. Would look better smooth but if they arent projectors, I think the waveyness is actually functional.
Old 09-18-2007, 03:41 PM
goldtooth's Avatar
yea, thats what I was thinking, BUT if I have projectors already behind that.... it kinda defeats the point/purpose... meh
Old 09-18-2007, 07:32 PM
Ok. Let this thread die. I cracked the yellow bulb housing and that was the whole point of the project. It was a big crack. lol. Then I got mad and lets just say its f*ked. Thanks, to all those that had input.
Anybody wanna hook me up with some IS300 projectors or a new set of fogs? Anybody wanna buy the unmolested one? Passenger side, I think. Hit me up. Otherwise...let this one die.
Old 09-18-2007, 08:15 PM
goldtooth's Avatar
I have some H3 projectors from a Honda, they are somewhat big but if you wanted to, you could "combine" them with the housing....so that it is easier to mount them to the car
I could give you approx length width depth measurements.... I am willing to let them go cheap. PM me if interested.
Old 09-19-2007, 10:04 PM
Garrick's Avatar
Originally Posted by goldtooth
I am willing to go cheap. PM me if interested.
I bet you are. When are we rolling to Connecticut?
Garrick is offline
Old 09-19-2007, 11:29 PM
goldtooth's Avatar
hahaha, u wish. stop making this thread anymore random....
Miket2006
03-01-2021 03:55 AM
my03maxima
04-29-2020 12:48 AM
howardis
12-11-2019 06:10 PM
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
Quick Reply: Please help me to open the foglight housing for a retro fit...
