Need new Alternator, please help..
SO i just started hearing this whining noise and i took it to machanic, he checked it out and he says that the bearing on the alternator is gone and it needs to be changed. New alternator with installation would cost $220. Is there any ways i can just get the bearing replaced? where can i find the part #? Also is there any place online where i can get alternator for cheap? Please help me out. .
Originally Posted by SuperFishstick
there was a recall for 97 and 98 maximas (i think it was those years). If u fall into this category go and see your dealer. He will replace your alternator 4 free!
exactly......got mine for free....
I took it diff. machenic and he thinks its the AC compressor. What should i do?
Originally Posted by Parsec
JAY25 can vouch for this. He says he'd install a supercharger over an alternator anyday ;-)
Originally Posted by ejj
Does it make any noise with the AC off? Because the clutch is disengaged, it wouldn't if it were the problem.
I don't think installing an alternator is nearly that complicated. I did the alternator in 2.5 hours. SC took 12 or so.
Yes it does make noise white the AC is off. Its a whining noise.
I would bet its the alternator then. The AC is directly below the alternator, which would explain how you could get them confused.
Well, Even when the AC is off, the pully for the compressor is still spinning as there is same belt for AC and Alternator.
Originally Posted by Wht98SE
As long your Max was built b/w 2/97 - 2/98 you qualify for this recall
Yeah, but he says SC is simple and tedious, whereas the alternator u have to wrestle with to take it out. I guess he doesn't like to flex his muscles
Originally Posted by wariow
How do you find out what year it is again? And you just go into any dealer and say I need the recall alternator?
Originally Posted by twiggy144
Ok now the big question. Is the car safe to drive like this? I am taking a 700 mile trip this weekend. Should i do it?
http://forums.maxima.org/showthread....lternator+fire
Look on the sticker in your driver door jamb, it should tell you when your Max was manufactured ... if it does fall within those dates you're eligible for the recall ... mine was 1/98 so I had my alternator replaced Summer '02
Doh, mine was made in 1/97 so I don't qualify?
A few days after mine started making noise, the alternator lit on fire!
This nissan USA link lists the VIN under this recall.
http://www.nissanusa.com/form/0,,act...-51054,00.html
TallTom
50
07-08-2022 09:54 AM
06-06-2017 02:01 PM
