help with the EGR system
Old 08-21-2003, 09:38 PM
Sleeps with his maxima!
sanjosemaxima's Avatar
Hey guys, I just pulled up an EGR System Hi/Low Flow code on my max and was wondering if anybody knew what would be causing a problem with the Exhaust Gas Recirculation system? Bad exhaust? Or something messed up with the EGR valve? Does anybody know where this is located?
thanks a bunch.
sanjosemaxima is offline
Old 08-21-2003, 10:24 PM
indigomax's Avatar
mmm i had the same a few months ago...just check the egr vacumm hose...i remove it, cleaned, re intalled etcccccccccc and the f..code always pulled by the ECu and after almost order a new egr valve, bla bla bla...i saw a a little hole on the hose that comes from the egr....and thats it...replace and never had again that problem.
indigomax is offline
Old 08-21-2003, 11:02 PM
thanks a lot man, do you know where i can find that hose, and the valve (dont have my chilton handy)
thanks
Old 08-22-2003, 07:33 AM
indigomax's Avatar
its easy...the egr is like a bell....under the maf-manifold, theres two, the egr valve and Bpt valve...both you can see some hoses coming from them...so take the hose and inspect each one.
Old 08-22-2003, 08:16 AM
enjetek's Avatar
thanks indigomax. sanjose if you need more info look at the post i made...includes the specific text for error code "1005". search the forums.
enjetek is offline
Old 08-22-2003, 03:11 PM
iansw's Avatar
You should test it yourself.
Wear some leather gloves and reach under the diaghram and rev the engine. If it moves up and down, then your EGR valve is working fine.
http://66.235.8.219/chilton/egr.jpg
iansw is offline
Old 08-22-2003, 04:15 PM
thanks very much every1, I will go check that stuff out asap.
Old 08-25-2003, 09:37 AM
Midknight MAXX's Avatar
Re: help with the EGR system
thanks a bunch.
Did yo get any other codes, like the infamous knocksensor code?
Midknight MAXX is offline
Old 08-25-2003, 12:47 PM
Re: Re: help with the EGR system
Yeah I got a knock sensor code, but I've always had that so im not really worring about that...
Old 08-26-2003, 08:54 PM
OK, so after checking for codes the first time I've had no CEL, so I checked for codes again today any only came up with an 0505, which is nothing... So now im kinda wondering if there is still a problem or not.
Can someone please describe better, where the actually valve is? Is it above or under the throttle body? is it metal disk?
thanks so much
Old 08-26-2003, 08:56 PM
iansw's Avatar
Under teh TB, just a little towards the front of the car.
Brass colored, about 3-4" in diameter.
iansw is offline
Old 08-26-2003, 09:45 PM
I think I know what ur talking about and i felt under there and didnt see anything that would move up and down?... I reved and and stuff and felt nothing (if it was the valve)
Old 08-26-2003, 09:48 PM
iansw's Avatar
You can't see it move up and down because it's under the metal disc. You have to feel the bottom side of it, basically. You can't see it at all.
iansw is offline
Old 08-26-2003, 10:04 PM
paulsfds's Avatar
That's wierd, I have the same problem, My CEL just went on and I got the same EGR System Hi/Low Flow code so I reset the ECU and then it gave me the 0505 code which is nothing. So then I reset it again it gave me 0505, did it one more time and then it went away...I drove around the block for a little bit and hasn't come back yet...
paulsfds is offline
Old 08-26-2003, 11:09 PM
yup, thats what happened to me... but iansw i said what i meant wrong, i know you cannot see under it (i ment feel)and i didn't feel anything go up or down.?
Old 08-26-2003, 11:31 PM
iansw's Avatar
hmmm...should do that at about 2500RPM.
You should at least manually be able to push it up and down. If not, then that's not the EGR....(There's something else down there that looks like the EGR, but isn't....I forget what it is right now)
iansw is offline
Miket2006
03-01-2021 03:55 AM
MichMaxFan
09-30-2015 09:18 AM
Socalstillen
09-26-2015 12:01 PM
bumpypickle
09-19-2015 01:07 AM
Quick Reply: help with the EGR system
