Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 08-21-2003, 04:58 PM   #1
Kevlo for President
Kevlo911's Avatar
Points: 41,379, Level: 100
Points: 41,379, Level: 100 Points: 41,379, Level: 100 Points: 41,379, Level: 100
Activity: 47.8%
Activity: 47.8% Activity: 47.8% Activity: 47.8%
IAC Vavle Adjustment Question
i have taken the golden "cap" off my IACV to make it like hte newer ones because i was scared that a screw might go into the engine. i have cleaned it too. now the prob, the car idles at 500-550 when in a gear. in park it is about 700. since i took hte cap off to make it like hte newer ones, i think the idle screw is adjusted differently then mine. should/do i need to turn the black plastic screw to adjust my idle? if so in which direction do i turn it. or do i need to clean my intake air filter?
thnx
__________________
97 Pearl White Max GLE
Kevlo911 is offline   Reply With Quote
Old 08-21-2003, 05:28 PM   #2
Points: 34,988, Level: 100
Points: 34,988, Level: 100 Points: 34,988, Level: 100 Points: 34,988, Level: 100
Activity: 25.7%
Activity: 25.7% Activity: 25.7% Activity: 25.7%
Send a message via AIM to njmaxseltd
Re: IAC Vavle Adjustment Question
Quote:
__________________
As the 4th gen ages, its owners get younger.
njmaxseltd is offline   Reply With Quote
Old 08-21-2003, 05:53 PM   #3
Jatan's Avatar
Points: 13,440, Level: 75
Points: 13,440, Level: 75 Points: 13,440, Level: 75 Points: 13,440, Level: 75
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Why would the screw go into the engine? Just tighten it back when you put the cap back on.
I cleaned out my TB and IACV, and now when I start the car in the morning (completely cold) the RPM is like 1200-1300 (was 1000 before cleaning). The other RPMs are like 50-100 higher too.
__________________
07 Maxima SL
Jatan is offline   Reply With Quote
Old 08-21-2003, 06:39 PM   #4
How do I clean the IAC valve...what exactly is it, I know to follow the large hose to the throttle body and is near the purple /pink connector...now which one is it and how do I clean it...need pics to clear up the confusion??????..help need to do this ASAP
wildmaxi is offline   Reply With Quote
Old 08-21-2003, 07:05 PM   #5
Points: 11,530, Level: 70
Points: 11,530, Level: 70 Points: 11,530, Level: 70 Points: 11,530, Level: 70
Activity: 0.2%
Activity: 0.2% Activity: 0.2% Activity: 0.2%
Send a message via ICQ to multiplexor
Click the image to open in full size.
It's like right beside the throttle body...
as for actually cleaning it... err not sure...
i've read you could spray it with carb cleaner?
__________________
2004 - Maxima SE - MT - Blue
2003 - Maxima SE - MT - Black - RIP
1996 - Maxima SE - MT - Starfire Blue - RIP
multiplexor is offline   Reply With Quote
Old 08-21-2003, 07:08 PM   #6
Activity: 0.2%
and yes... that is a pic i took with my crappy digicam...
it's from the haynes manual...
__________________
Old 08-21-2003, 07:27 PM   #7
Jatan's Avatar
Activity: 0.7%
Just take it out (3 screws) and on the inside there is a metal cap that you unscrew. I cleaned the whole IACV inside, the cap that was removed inside, and the area under the cap. Use carb or throttle body cleaner.
__________________
07 Maxima SL
Old 08-22-2003, 02:24 PM   #8
Kevlo for President
Kevlo911's Avatar
Activity: 47.8%
well after i cleaned the IACV the first time, i tightened the screws really tight. and then i asked hte question about the screws and i was told i can take it off. i did take it off and when i was unscrewing the 3 screws, they were very easy to take off.
so, can/should i adjust hte black plastic screw on the IACV
__________________
Old 08-23-2003, 07:57 AM   #9
Kevlo for President
Kevlo911's Avatar
Activity: 47.8%
New?JDM Engine Available?
there is my other thread
__________________
Old 08-23-2003, 08:22 AM   #10
Points: 12,548, Level: 73
Points: 12,548, Level: 73 Points: 12,548, Level: 73 Points: 12,548, Level: 73
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
I think your 700rpm in park falls under normal range. However, if you are concerned your base idle may be off, the proper way to confirm and adjust that is adjusting the black IACV set screw with the TPS (throttle position sensor) disconnected.
(1) With car off, disconnect TPS. Make sure you previously have driven the car and it is normal operating temperature. Make sure your A/C-heater is off.
(2) Start the car and rev it a few times... then let the rpms drift to base idle. If need be, increase/decrease the base idle rpm to normal range via the IACV set screw (black plastic). If the limits of the set screw have been reached but the idle rpm is still out of spec, you will have to adjust the throttle plate screw to get it in range, and then fine tune with the IACV screw.
(3) Reconnect the TPS and start the car.
Mishmosh is offline   Reply With Quote
Old 08-23-2003, 08:30 AM   #11
Kevlo for President
Kevlo911's Avatar
Activity: 47.8%
when i test hte base idle do i put into the gears or not? if so to i turn it until hte idle is at around 700 in hte gears?
__________________
Old 08-23-2003, 08:33 AM   #12
Kevlo for President
Kevlo911's Avatar
Activity: 47.8%
also do i dissconnect both connectors?>
__________________
Old 08-23-2003, 11:48 AM   #13
Activity: 0%
When in gears, you are then NOT looking at "idle." The procedure is only for park/neutral. My car only has one TPS connector but if yours has two, then by all means disconnect them both. When the TPS is connected, your ECU is always trying to correct the rpm so you should not adjust the IACV under that circumstance.
Old 08-23-2003, 03:49 PM   #14
Kevlo for President
Kevlo911's Avatar
Activity: 47.8%
ok people, i just did hte "base idle" and it was at 400, i turned about 1 and a half turn counter clockwise and it went up to 750. i turned off car and connect hte tps. i turned back on it was a smooth turn on, i turn on a/c, rpms all good. i turn off ac and then put into reverse. the rpms drop to 550 but it doesn;t vibrate the steering wheel like it did eariler. i put in neutral and it goes back up to 700. i put into d and drops back down to 550 and no vibration. remember the car is not moving, i have my foot on the brake and when i let go, the rpms still are at 550. should i be concerned at al about hte rpms dropping to 550 in the gear or not since it doesn;t vibrate? also the rpms are at 650 when hte ac is on while i am in a gear.
thnx for your help
__________________
Old 08-23-2003, 05:13 PM   #15
Activity: 0%
In gear rpms is affected by a lot of things: load, speed, gear...etc. As long as it doesn't shake like it's choking or about to stall, I wouldn't worry about it. Then again, I don't have an automatic so can't really say for sure...
Old 08-23-2003, 07:45 PM   #16
Jatan's Avatar
Activity: 0.7%
Got my tranny rebuilt and now it stalls sometimes and shakes. My dad said it's normal and I need to let it break in. I'll wait a few more days and go back to the shop if it continues
__________________
07 Maxima SL
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
