First time w/ nitrous at the track, fried the clutch...need help!
Well i just came back from desoto speedway after running my car. It was my first try with my nitrous setup (50-shot, wet). Well, my first run i ran a 14.5@97, but noticed what i thought to be my tires spinning in every gear. Well, indeed, it turned out to be my clutch slightly slipping. So i run again about 1 hour later, and my clutch never really engaged, it pretty much spun the entire way, leading to only a 14.8@93.
Well, i figured my clutch would still be ok, but i went home anyways. I decided to punch it to see if the clutch was still slipping, and bam, completely slipped in a 1-2 shift. Its pretty much shot, no more racing...
Now, my question is, i know theres alot of different clutches out there, im not looking for a racing clutch or something that will shatter my tranny, but i need something that will at least hold this 50-shot, later to be a 75-shot. Are there any clutches you guys can recommend that are running that much power?! Any sites, prices, experience and everything is appreciated. This is shiiiiiiity!!!
Eric
Eric
I love my EXEDY Stage one Clutch. I have no chatter or any problems with it. I am also running a fidanza flywheel and have not driveability issues. Though I am not running nitrous... I can chirp third if that helps...
Originally posted by guestNX
act street (part number NM1-HDMM) would be a good one for the amount of power you were talking about. just don't be stupid with it (shifts). It lists for mid 300's , and can be purchased for upper 200's
good luck
good luck
Eric
Eric
Originally posted by 99Maxima5sp
whats the part number on that clutch?!?
Eric
Eric
Originally posted by Craig Mack
Eric you dumb kid, you will need 100hp/120tq via a 100 shot to keep up with MEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE.
MWUAHAHAHAHAHHAHAHAHAHAHHAAH
And thanks eternity059...I look into that one...
Eric
well....well.....my ***** is bigger than yours. AND i have a snail that makes weird chirping noises that attracts mondo attention.
Erics car with 50-75 shot of ***** juice, rice sauce, cheater gas < Craig Mack Blown at 10psi
You still don't have one thing though that Nitrous gives you. Can you say torque?
Originally posted by Keith97gxe
Hey now dont be bustin on people runnin nitrous. Call it all you want but when he beats you then you wont be talkin.
Yeah, if you don't have to stop to drop your tranny and clean out all the shavings from a burnt stock clutch like the originator of this thread.
My tranny never broke or anything, i dunno what your talking about. All i mentioned is that i spun the **** outta it and i cant spray anymore. My car still works fine, i can drive it normally. I just need a new clutch...
My tranny wont break on a 75-shot, let alone a 50-shot...
Eric
Eric
Eric
don't be too confident in the tranny. mine broke and all I have is y-pipe and intake.
Very true. God forbid anything like that happens, i do have an extended warranty that covers my engine and tranny. So hopefully it would be taken care of...
Im also gonna look into whether or not it covers my clutch...never know...
Eric
Also, my dads insisting that i should just change my pressure plate and it will be all good. But those run upwards of 100 bucks, so shouldnt i just get an Exedy clutch kit and replace everything on one shot since i already have 88K on my tranny?!?!
Eric
Eric
Eric
Eric
Originally posted by SprintMax
i ran 100 shot with my ACT.. my clutch is fine
too bad Craig's car will never see 385ft/lbs tq
1FSTMAX:
Look at those two beasts leading the way, with all the small displacement rice behind them. True small block beasts with tiny blocks behind them.
Did you ever get those dual exhausts? I remember you PM'ing me about it a while back. Let's see some pics...or do you still have a single fart-back?
1FSTMAX:
1FSTMAX:
Team STILLEN
08-10-2015 04:29 PM
