Could I please get some quick help on how to get my corner light off?
Old 08-15-2003, 04:50 PM
Sorgasm's Avatar
I'm trying to do the brighter corners (or parking light, the ones right beside the headlights) and I can't get the cover off. I took out the screw as instructed on http://www.danimsta.com/ but they still seem stuck. I don't want to break anything. Any suggestions?
Sorgasm is offline
Old 08-15-2003, 05:21 PM
Sorgasm's Avatar
Sorgasm is offline
Old 08-15-2003, 05:24 PM
Kevlo for President
Kevlo911's Avatar
ok, stick a flat head screwdirver and stick it inbetween the headlight and corner light, u will see a ball and socket type joint. stick hte screwdriver inbetween the joint and twist. that should pop it out
Kevlo911 is offline
Old 08-15-2003, 05:53 PM
Sorgasm's Avatar
You sir, are truly a King among men. You make Gandhi look like a child pornographer. Haha, naw but really though, thanks for the tip. It did just the trick.
Ok, so it took longer than I expected but I put in some Xtravisions and orange corner bulbs. I finished just as the sun went down. It looks really good. I was gonna do the brighter corners mod but I gave pretty firm pressure and that top nub wasn't low enough to fit where the bottom one goes and I didn't really feel like risking a broken bulb on a friday night when I'm about to go out. How hard can you really push on those bulbs without breaking them? I might do the brighter corner thing later now that I know how to get the corner off easy. Thanks again Kev.
Peace.
Sorgasm is offline
Old 08-16-2003, 10:52 PM
MienMaxima's Avatar
Darn....didn't know that. I posted a message just two days ago with the same question. I got great advice except for the part about "sticking the screw driver in between the joint and twist" part. I just assumbed by pulling hard and straight it would just pop the ball out from the joint. But instead, I ended up braking the plastic bracket (the ball was still in the joint, but the corner lamps came off =/). What my question is, and what I'm hoping, is this ok after i put the light assembly back ? I mean I figure the screw under the hood would be strong enough to hold the lamp in....also I would only be concerned about water, condensation, winter snow, etc. getting in. Any thoughts ?
MienMaxima is offline
Old 08-17-2003, 06:15 AM
Kevlo for President
Kevlo911's Avatar
duck tape it, or use silcone to seal it up. that way nothing gets in the corner lamp. also if u want to know if it is gonna stay, when it is screwed in--pull onit a little and see how mcuh it moves
Kevlo911 is offline
Old 08-17-2003, 10:02 AM
MienMaxima's Avatar
Where or what should i duct tape ? Also, if i use silicone to seal it, would there be a problem is, let's say, I had to take off the lamp assembly off again ?
Old 08-17-2003, 10:17 AM
Kevlo for President
Kevlo911's Avatar
good point, it might break again. you can cut hte nub off and use silicon or buy a new corner lamp for 30$
Kevlo911 is offline
Old 08-17-2003, 11:17 AM
MienMaxima's Avatar
It's ok. I'll just take a chance that it won't fall off. It's better than shelling out 40-80 for two head lamp assemblies when they're not even broken yet. Thanks anyways !!!
Old 08-17-2003, 05:52 PM
mendon11's Avatar
weeelllllll...the top nub isnt supposed to go in the bottom...its the other way around. you clip the top and tape over it. then put the bottom nub where the top should be. i just did this two weeks ago and its soooo easy. such a quick little mod but makes the max look soo much better. in my opinion anyway. give it a try anyone who hasnt
mendon11 is offline
mvm062
11-30-2020 09:00 AM
MaxLife17
06-27-2019 01:37 PM
MaxLife17
09-08-2015 02:36 PM
maximusrising
09-02-2015 09:55 AM
A32goldylocks
09-02-2015 06:39 AM
Quick Reply: Could I please get some quick help on how to get my corner light off?
