Problem w/ fuel injector. Spitting too much gas at once.
I have a 96 Max. On a 10 gallon, I can get 130 miles out of my car in the city. Whenever I step on the gas pedal and gets the rpm up to 3000, once I release the pedal. It drops back to 1000 rpm in an instant. From what my friend told me, it should come back down to 1000 rpm slowly, not free fall. He told me the fuel injector could be the problem. My CEL is giving me the EVAP errors(0903 and 0807). I'm not sure if that contribute to the problem also.
I've tried putting the STP fuel injector cleaner, but the dial still free falls back to 1000rpm when I release the gas pedal. I've replaced the ks, O2, PCV, ICAV, fuel filter, air filter and oil change.
Could it be the injectors are spitting out too much rich fuel?
Anyone have problem with the max where it spray too much fuel?
My car is eating up way too much fuel.
Appreciate for the comments.
Re: Problem w/ fuel injector. Spitting too much gas at once.
Re: Re: Problem w/ fuel injector. Spitting too much gas at once.
Originally posted by Stephen Max
Does it do this in gear while driving? Sounds like you have a torque converter with a high stall speed.
Doesn't matter while i'm driving or idle. The pointer does a quick drop from 3000rpm to 1000rpm whenever I release the gas pedal. Thanks for you help.
03-12-2020 12:06 AM
aminus21
09-12-2015 04:53 PM
