Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-14-2003, 06:15 PM   #1
I H8 COPS
Micro-second pauses in acceleration - Going through HELL!
I got 55K on my 5-spd 99 SE-L. Changed the spark plugs today, checked the fuel injectors (which are in perfect condition), checked throttle body (perfectly clean) and I still experience micro-second pauses in acceleration...especially in the 3.5 to 6 RPM range. Any suggestions? I have no check engine light on and it's been happening for well over 4 months. Change my oil regularly, put only premium gas in etc. etc. What can be wrong? Max is all stock...except for a K&N cone filter. This is really ****ing me off now. I can't even race a stock accord because this **** slows me down. I seems as though the car chokes or something. I was thinking of a somewhat defective fuel pump but somebody told me if it was that, then I would experience a much bigger and noticable problem. Lastly, as suggested by others, the car does NOT burn more fuel then it ever did before.
HELP ME!
Old 07-14-2003, 06:21 PM   #2
Send a message via AIM to sryth
Re: Micro-second pauses in acceleration - Going through HELL!
Quote:
How, exactly, do you experience these pauses? Is it felt, or do you notice it on your speedometer? I noticed that my speedometer slows down sporadically between 55 and 60 mph.
__________________
'98 SE 5spd Pebble Beige, PRCAI, Stillen Y, Stillen FSTB, VLSD, Eibach Pro/KYB AGX.
sryth is offline   Reply With Quote
Old 07-14-2003, 06:28 PM   #3
Send a message via AIM to drewm
Does it feel like it's in sync with engine speed or is it more random?
__________________
http://maxmods.dyndns.org/
99SE-L Sold.
On to bigger, better and faster things....
drewm is offline   Reply With Quote
Old 07-14-2003, 07:00 PM   #4
I H8 COPS
Quote:
It is quite random...however...it happens mostly between the 3 and 6 RPM range. The pauses are very noticeable...by that I mean i feel the pauses myself. Imagine you max accelerating all good and all of the sudden just choking (pause sort of thing...i don't know exactly how to describe it) during which it does not accelerate and lasts only like a 1/3 or 1/4 of a second...very very fast. And than it still accelerates and it happens again. On average when between the 3 and 6 RPM I will only experience like 2 pauses or so, regardless of what gear i'm in (that is why I emphasize RPM here instead of speed e.g. 50 or 60mph...NO) It feels like the fuel is being cut off somehow during that split second. It only happens, however, when I accelerate hard. If I were to accelerate in first from 1 to 6 rpm with an average or below average intensity...the microsecond pauses do not occur.
Old 07-14-2003, 07:02 PM   #5
Traitor
mzmtg's Avatar
Send a message via AIM to mzmtg
Change your fuel filter. Check your ECU for the 0304 knock sensor code. Wrap the boots of your ignition coils in a layer of electrical tape, they may be shorting to the valve cover.
__________________
1998 323is
GeorgiaCarry.Org
"The twin-cam six is so sweet and eager,
the five-speed so perfectly slick,
the chassis so hunkered down and trustworthy,
think about it - what if there is no afterlife?
This may be as good as it ever gets."
- Car and Driver, May 1996
mzmtg is offline   Reply With Quote
Old 07-14-2003, 07:15 PM   #6
I H8 COPS
Quote:
You say to check the ECU for 0304 but it's been 4 months and the ECU did not throw a check engine light on even once. Also, where are the boots of my iginition coils located? R u saying that the stock rap sucks?
Old 07-14-2003, 08:01 PM   #7
Traitor
mzmtg's Avatar
The knock sensor code is a "ghost code" it will not cause the check engine light to come on. Check anyway.
Each ignition coil is attached to each spark plug with a long rubber connector, or "boot." Sometimes the rubber of the boot will deteriorate. This can cause the spark energy to short circuit to the valve cover instead of reaching the spark plug. Removing the coils and wrapping the boots with a layer of electrical tape can solve this problem, or at least rule it out as an issue.
Old 07-14-2003, 09:16 PM   #8
Check the Mass Air Flow sensor. If you recently put in a K&N cone filter, an excessive film of oil may have fouled the MAF heater element. If that is the case, it would cost near $400 to replace it. Install is a "do-it-yourself" item.
I doubt it would be the knock sensor. A knock detection would reduce the power but it wouldn't result in pulsating power as you describe.
The fuel injectors and filter could also be a likely cause. An electrical issue or clogging could cause the issue you describe.
__________________
95 SE 5-Speed
chris j vurnis is offline   Reply With Quote
Old 07-14-2003, 09:24 PM   #9
Father of the 00 VI
Send a message via AIM to krismax
I have the same problem ,changed spark plugs ,knock sensor, fuel filter.still hesitates
__________________
VQ 3.5 12.72 @ 108.33 NA stock tune and rev limit 1.83 60ft 0-60 3.88 TOTALED
FOR SALE CRUISE CONTROL UNIT ,ANTIFREEZE OVERFLOW,96 MAX BODY CONTROL MODULE,PEARL POWER MIRRORS LEFT AND RIGHT,2 RSX LEATHER SEATS,96 MAF,knock sensor, PM FOR DETAILS
krismax is offline   Reply With Quote
Old 07-15-2003, 12:54 AM   #10
What kind of spark plugs are you using? If they aren't NGKs that's your problem right there.
__________________
99SE-L Sold.
Old 07-15-2003, 03:24 AM   #11
I H8 COPS
Nope...I'm using the NGK's. I always go with the originals.
Quote:
And about the K&N cone filter oil getting on the MAF heater element...how can I check if that is the case? Where is this element anyway?
Old 07-15-2003, 06:35 AM   #12
Traitor
mzmtg's Avatar
If you remove the MAF and look into it, you can see the sensing element. It's a couple of small wires in a little hole, right in the middle.
You can try cleaning the MAF by gently rinsing the element with rubbing alcohol.
Also, check the ground connection to the MAF as described here:
Do Hids Have High/ Low Beam ??
__________________
1998 323is
GeorgiaCarry.Org
Old 07-15-2003, 09:58 AM   #13
Send a message via AIM to slop00
I have had this same problem for about 4 months as well. I have a 99 se 5 speed. I noticed the problem before I put on my intake on. I thought it was bad gas but with the intake on you can hear it make a popping sound. It is only at about 3500 - 6 and only at WOT. It happens randomly. I talked to my mechanic and he said that it is one of my coil packs going. If you keep on the throttle while it is doing this hesitation the check engine light will blink but not stay on and the ECU doesn't store a code. I red a post a while ago from some who had the same problem and they eventually just gave in and bought 6 coil packs and the problem went away.
slop00 is offline   Reply With Quote
Old 07-15-2003, 10:18 AM   #14
Send a message via AIM to njmaxseltd
I agree, it's a misfire probably do to a coil pack.
__________________
As the 4th gen ages, its owners get younger.
njmaxseltd is offline   Reply With Quote
Old 07-15-2003, 11:53 AM   #15
The thing that really sucks is that it won't do it while reving the motor so you couldn't check voltage on the coil pack. It only does it while the car is moving. I think mine is about to go so then I will know which one. From my research, apparently with 99's it will more then likely be coil pack 2. That is apparently the one that fails.
If anyone knows a way I can figure out which coil pack it is I would appreciate it.
Slop
Old 07-15-2003, 12:39 PM   #16
U wanna try me young boy?
Scruit's Avatar
Unplug the knock sensor harness just forward of the TB and plug a 470k resistor across the terminals (so that the computer sees the resistor). If your hesistation is gone then the problem is narrowed to the kncok sensor circuit. if the hesitation is still rpesent then the knock sensor circuit is eliminated.
I don't like your screen name.
Scruit is offline   Reply With Quote
Old 07-15-2003, 01:36 PM   #17
I H8 COPS
Slop
Those coil packs...is that the long rubber thing on top of the spark plug? Should I replace them all? If so...how much are these? Also...how can the coil packs go bad...I mean they look OK to me.
Old 07-15-2003, 03:29 PM   #18
I H8 COPS
Slop
Correct me if I'm wrong, but wouldn't it make sense to buy one coil pack and test it out by replacing each of the 6 sequentially and having a test drive after each replacement? Then we could see which one is bad or which one is good by process of elimination. Saves us 5/6 of the price for all...right?
Old 07-15-2003, 03:55 PM   #19
Slop
That's amazing.... that it always happens to be the #2 coil, because that's the one on my 99 that went out also.
For the orig poster, it's here:
1 3 5
2 4 6
front of car
I'd definately try to swap that one out with a new one first.
Also, the front bank and rear bank coils are different, so you can't swap between front and rear.
__________________
99SE-L Sold.
Old 07-15-2003, 06:34 PM   #20
I H8 COPS
1 3 5
2 4 6
front of car
Thanks...that really helps! I'll start with # 2.
Old 07-15-2003, 09:38 PM   #21
I H8 COPS
hmm
I just thought of something...what if I wrap the defective ignition coil in electric tape? You think that might temporarily help dipict the defective coil? Or will electric tape do nothing to prevent say a misfire that is already happening?
Old 07-15-2003, 10:27 PM   #22
Send a message via ICQ to spiff56747 Send a message via AIM to spiff56747
Re: hmm
spiff56747 is offline   Reply With Quote
Old 07-16-2003, 03:11 PM   #23
I H8 COPS
WOW
wrapped ignition coil #2 with electric tape today. Wrapped it all around...very nicely with lots of layers etc. All I have to say now is W O W ! It freakin worked! My pauses stopped! It's very weird because when I took the ignition coil #2 out (the one most people told me will most likely be defective for some odd reason) the rubber and everything on the coil seemed perfectly normal. I did not see any deteriorating rubber or anything of that sort. I guess it somehow misfired even though you could not see any defects with a naked eye. AMAZING!
Old 07-16-2003, 08:06 PM   #24
Send a message via MSN to maxima_se007
In the last 2-3 weeks I think I had what you are talking about happen to me in my 96 SE 5spd. It kind of feels like you hit a very small patch of ice. I know that sounds weird but that's the closest thing I can think of that feels like this hesitation. It only seems to do this on WOT like mentioned before on my max too. Let us know if you do anything to try to correct it and if it works or not.
maxima_se007 is offline   Reply With Quote
Old 07-16-2003, 09:29 PM   #25
Dyno plot says I have the most area under the Administrator curve
SteVTEC's Avatar
I have the same hesitation issue right now. You get on the gas and you start accelerating, but then there is this momentary lag for just an instant, and then you're back to accelerating again, right? If so, I'm getting this from lower RPM's also, not just above 3k.
Coil #6 went bad awhile ago. Replaced. Hesitation still there occasionally. Knock sensor is now bad. Bypassed temporarily with 470k resistor. Hesitation still there. More frequently. Tracked timing on OBD-II logger while driving. Lag does not follow timing advance/retard (thought it might have been related to the knock sensor), so it's not that.
I'll try this Coil #2 trick with wrapping the boot.
While I'm ordering my knock sensor, I think I'll probably order another a front and a rear coil for not if but WHEN I need them, and some other stuff too.
__________________
Total Power Area Under the Curve Divided by Weight STILL oWnZ j0o
SteVTEC is offline   Reply With Quote
Old 07-16-2003, 10:25 PM   #26
I H8 COPS
Quote:
actually...now that I think about it I also had hesitation from lower RPM only not as frequent as when in the 3 to 6 range
Old 07-16-2003, 11:23 PM   #27
matty's Avatar
Send a message via AIM to matty
Guys With Hesition
I beleive it has something to do with Backpressure...ever since I put on my Cat-back 2.5" all the back, I have felt that same hesition..it wasnt there before the exhaust went on, even not with just the y-pipe..
So, everyone that has the hesistion, do you have a cat-back and y-pipe
-matt
Remember when you start modding these engines, everything wont act the same
matty is offline   Reply With Quote
Old 07-17-2003, 08:48 AM   #28
SteVTEC's Avatar
I am 100% stock, not even a K&N panel so I don't think it's has anything to do with aftermarket parts.
__________________
Old 11-27-2003, 12:34 AM   #29
Custom User Title...
i'm happy to see that i'm not the only one that has had this weird thing happen. did all of you determine that it was a bad coil pack?? i've had it happen about 4 times and it freaks me out. i was hoping it was just the fuel filter or something and hoping it's not an $80 part. the max has seen better days. that thing on top of my tempormental speedometer that sometimes needs to be hit to get back to working, makes me sad and annoyed.
any help or new info guys?? thanks
Jepht20 is offline   Reply With Quote
Old 11-27-2003, 01:22 AM   #30
Send a message via MSN to MAXimumHP
It's odd, but I think I might also experience this. I thought it was just in my head. My dyno even shows the spikes. I may try the coil wrapping, otherwise I am going to try to find coil packs from a 97 and replace them all. Whatever they did to the coil packs in 99, it's not good.
MAXimumHP is offline   Reply With Quote
Old 11-27-2003, 01:24 AM   #31
BTW, anyone know for sure if the coil packs are interchangeable, I wouldn't see why not.
Old 11-27-2003, 06:57 PM   #32
I'm having the exact same issue right now! Our coil packs SUCK on the 99's. I've already replaced KS, fuel filter, #5 cylinder coil pack, and I'm replacing #3 cylinder coil pack tomorrow. If this persists, I'll wrap the whole bunch of them in frickin electrical tape and see how it goes.
Shift_Power is offline   Reply With Quote
Old 11-27-2003, 08:11 PM   #33
Send a message via ICQ to MystiWink Send a message via AIM to MystiWink Send a message via Yahoo to MystiWink
Well I am another with the same issue. Is anyone getting really bad idle? because I have all the symptoms that u guys have. What happens is when I go from crusing to neutral my idle will just drop and it doesnt do it all the time seems to happen more when its hot out. I have replaced my Knock,F.Filter,checked Fuel Injectors,replaced O2 sensors. I have had codes for my knock sensor and my right bank running to rich. I have took it to mechanics and they cant find whats going on either. I wasnt sure if this hesitation is connected to my bad idle.
MystiWink is offline   Reply With Quote
Old 11-28-2003, 08:44 AM   #34
I'm amazed with the number of people with this problem. In some ways I'm happy to know I'm not the only one, in others I'm not so happy because I have this feeling the coils will continue to cause problems.
Old 11-28-2003, 09:50 AM   #35
Father of the 00 VI
Ive had this prob bad for about two years , just solved it with a complete overhall of my egr system and put a newer MAFS in.
When i put on my pathy TB my airflow increased alot which made my prob worse, i assumed that the TB was adding to the prob,it wasnt its just that the extra flow was taxing my bad MAFS and clogged egr system.
With those problems fixed my airflow was 10 to 20% more , my car felt like a beast , i had to dyno ,when i did i was surprised!
Old 07-30-2009, 09:39 PM   #36
My 1997 Maxima HAD the same hesitation problem. I checked the front sparks plugs (2,4,6) and found #2 was broken (could spin top half). So I replaced it with a Bosch plug, but there was not much improvement. The nex day I replaced all the plugs with NGK ones, ohm checked all the coils (all ok), and wrapped them all with electrical tape. Problem solved, no more hesistation. Now onto how to increase power; engine seems a bit sluggish.
Eric97 is offline   Reply With Quote
Old 07-30-2009, 11:11 PM   #37
The Dirty Pearl
pmohr's Avatar
Quote:
You are aware that the OP no longer cares, correct? Hell, he's no longer on this forum.
This thread is over 6 years old.
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 07-30-2009, 11:48 PM   #38
Well... This thread did help me solve the same problem and I am sure there are other like me who have also benefited from it.
Old 08-04-2009, 07:37 AM   #39
It helped me out as well. I had little faith that it could be such an easy fix. But this morning on the way to work it was wonderfully smooth. I am so glad I found this thread!
DIAMONDS98SE is offline   Reply With Quote
Old 08-04-2009, 11:01 AM   #40
Send a message via MSN to Blackwind
oh sweet jebus.
__________________
"9 out of 10 Housewives approve of this product."
Blackwind is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
