Changing winter to summer tires yourself
Old 05-03-2003, 09:10 AM
davey6693's Avatar
Ok, I'm bored, penniless and have seven hours, and I'm considering changing over my winter tires to summer tires on my own (and getting them properly balanced in a week or so). Is this something I can consider doing myself, or is it a big no-no?
Thanks,
Dave
davey6693 is offline
Old 05-03-2003, 09:32 AM
Black97GLEnj's Avatar
Re: Changing winter to summer tires yourself
Thanks,
Dave
Do you want to switch rims and tires?, or put a different set of tires on the same set of rims?
Black97GLEnj is offline
Old 05-03-2003, 09:45 AM
davey6693's Avatar
Re: Re: Changing winter to summer tires yourself
Different set of tires on the same rims. I've just about given up already actually The problem is removing the old tires with the equipment I have. It ain't happening... Oh well
Old 05-03-2003, 12:17 PM
Re: Re: Re: Changing winter to summer tires yourself
You need a tire machine to do it... you'll never do it with hand tools
Old 05-03-2003, 05:50 PM
Allen's Avatar
you might wanna try going to some nearby highschools and seeing if they have an auto shop. if they do, check if they have a tire machine. i know mine did and they never used it, and if you just ask nicely the shop teacher will do it for you or let you use it yourself. they do this because it lets the students there see how the machines work and stuff.
Allen is offline
Old 05-03-2003, 06:06 PM
KWheelzSB's Avatar
There's actually a tool sold in off-roading magazines that allows you to "break the bead" & remove a tire from a wheel, as well as do the re-mount.
(It's meant for trailside emergencies, when help is far away).
I don't see why it wouldn't work on a car wheel/tire, but who knows.
I don't think this job is worth the hassle or cost of the tool, personally. The difference in cost between a straight balance and a dismount/remount/balance at a tire-shop isn't going to be that much.
Go do something fun w/ your 7 hours!
KWheelzSB is offline
MAXSE5SPD
09-17-2022 04:00 AM
MR2 T'd
07-09-2021 05:06 AM
fastcarny
10-06-2015 10:42 AM
alahjahwan09
18
09-21-2015 09:12 PM
jfl330
09-04-2015 01:44 PM
Quick Reply: Changing winter to summer tires yourself
