Just finished wrapping my y-pipe
My y-pipe has been making my car sound like a old VW Beetle for the past couple of months. I wrapped the y-pipe with 2 inch header wrap and the noise is gone! I followed the instructions on www.motorvate.ca and they were very helpful and easy to follow. I recommend this fix to anybody with a noisy y-pipe.
Originally posted by bhmax
I just installed my Warpspeed aluminized steel y-pipe recently, and hope this doesn't happen to me. Is your y-pipe the same, or do you have one of their stainless steel pipes?
Originally posted by iansw
My WSP Pipe is extremely loud....
Well, that was until I wrapped it last summer....It's fine on there.
And I live in Seattle - land of moisture!!!
I was actually going to wrap mine today, but ran out of time. I will probably do it on Sunday. I have a SS Warpspeed y-pipe with the VW Beetle sound too, the sound is more evident when the car is cold, not as annoying when it is warmed up. I was told that these new WSP y-pipes did not have this problem. I am still very happy with the performance part of the pipe though. I'll see how it goes.
Originally posted by Nismo
let me know how it holds up as time goes by. I live in CA so no salt issues here but it does get alot of rain sometimes. I want to wrap my whole exhaust but I keep hearing how wraps lessen the life of the exhaust.
besides, it only snows here maybe 1-2"/year.
Wrapping the y-pipe should help you pass smog checks for those of you in California and other emissions sniffing states. It will help retain heat in the exhaust system, helping to keep the catalytic converter hot enough to do it's job. Keeping the exhaust gasses warm is supposed to improve exhaust scavenging by keeping up exhaust flow velocity.
-V
-V
I used like 40 feet of DEI Exhaust Wrap. I did a few wraps around each starting point. Used about 5 hose clamps, might put a few more on there since some sections look a little loose already.
Also, it's easier to wrap if you get the whole wrap a little damp before you start to wrap (tip from mtrai760)
It's like $45 at summitracing.com
The other 10 feet was used to partially wrap my B Pipe. Heh....
-V
-V
-V
-V
Well, I wrapped my y-pipe earlier today and I am happy with the results. I only wrapped the flex section and about a couple of inches past it on either side. When I start going from a dead stop, the annoying noise is greatly reduced, and I can now hear the slight rumble from the rest of my stock exhaust, this was previously masked by the crickets. I hear a slight sound at higher RMP's, I will probably wrap the whole thing next weekend. I highly recommend this if you have the old VW Beetle/cricket sound.
Im planning on wrapping the entire exhaust soon-ypipe,bpipe all the way to the muffler(except cat), how many feet do you all thing I need? im probably going to be using 2 inch thick wrap but need to know how long? btw whats the cheapest, best place to buy wrap?
Re: Just finished wrapping my y-pipe
We don't suggest wrapping header wrap on a flex section because it retains moisture and heat but it should not be a big problem, they are afterall stainless steel. If you have a noisy Y pipe it is usually a mis-applied gasket or occasionally the fibre gasket will burn out if not tightened correctly and it will get loud. I have not seen an actual leak in over 2 years. So far I have yet to hear one we have installed which is louder than stock but we did have someone come in with a burned out gasket once.
We just installed one of our new equal length Y pipes on our 96SE and it was real quiet. We are now running an equal length Y pipe, MS cat, 2-1/2" B pipe w/res and a Magnaflow double wall tip street series muffler. After we get some miles on it we'll be dynoing to see how it compares. If we like the results we will probably offer them only for the 4th gens. We realize Stillen did one but they used thin tubing, their 2-1/4" collector and it was basically a crappy design. We'll be posting some photo's on our website after the dyno's.
regards
Dallas
regards
Dallas
04-16-2020 05:15 AM
