Socket size for stock 97 SE wheel lug nuts?
Old 03-25-2003, 12:50 PM
Slowpoke's Avatar
What size socket do I need to remove the lug nuts on stock 97 SE wheels? I need to do some brake work this weekend and shop that mounted my tires torqued the nuts too tight to get off with the stock wrench.
Slowpoke is offline
Old 03-25-2003, 01:25 PM
cydrive's Avatar
Re: Socket size for stock 97 SE wheel lug nuts?
hey bro, this is not going to be much help but I was trying to tighten my lugnuts, had everything up to a 21mm- did not work. Like I said, not much help but i bet its a 22 though!
cydrive is offline
Old 03-25-2003, 01:51 PM
ZuMBLe's Avatar
Re: Re: Socket size for stock 97 SE wheel lug nuts?
I really doubt its a 22mm. 22mm is the size of the bolt at the bottom of the strut. It's huge. I'm thinking its 19mm.
ZuMBLe is offline
Old 03-25-2003, 04:40 PM
StygianMax's Avatar
That's strange. I just pulled my '97 SE lugnuts off with a 21mm socket and it fit perfectly.
StygianMax is offline
Old 03-25-2003, 04:54 PM
Rogo02SE's Avatar
I never had to use a socket wrench so I'm not sure
You should have a lug wrench in your car.
Rogo02SE is offline
Old 03-25-2003, 04:56 PM
slizan99's Avatar
i believe it's 15\16... standard not metric
slizan99 is offline
Old 03-25-2003, 05:45 PM
karguy's Avatar
I have a 97 I30 and 97 SE and a 21mm fits lug nuts on both cars. I am certain as I rotated tires today!
karguy is offline
Old 03-25-2003, 06:13 PM
Jamsan's Avatar
throw a big a$$ bar on the end of the stock wrench, and im sure itll come off
Jamsan is offline
Old 03-25-2003, 06:16 PM
Asian_N02's Avatar
just changed my suspension on my 97 I30...21mm fit perfect on my lug nuts...
Asian_N02 is offline
Old 03-25-2003, 07:01 PM
NismoSER's Avatar
Everything on a Nissan is going to be metric. Its from Japan, remember?
Nissan uses lug nuts that take a 21mm socket on all their passenger cars.
NismoSER is offline
Old 03-25-2003, 07:12 PM
cydrive's Avatar
i must've been doing something wrong then. 21 mm Slowpoke!
cydrive is offline
Old 03-25-2003, 09:31 PM
StygianMax's Avatar
15/16" = 23.8mm (1'=25.4mm) Using that socket will eventually round off the corners of your lug nuts. Getting a 21mm socket is worth the investment.
Old 03-26-2003, 03:01 AM
Slowpoke's Avatar
21mm it is. Thanks for the info guys!
Slowpoke is offline
Justin Kroll
09-02-2015 11:06 AM
umnitza
09-01-2015 01:03 PM
Cant_Get_Ryte
08-28-2015 06:41 AM
maximaham
08-20-2015 10:23 AM
follyburr
08-12-2015 08:57 PM
Quick Reply: Socket size for stock 97 SE wheel lug nuts?
