H&R? Tokico? GR2?
H&R? Tokico? GR2?
I am planning to lower my "new" 97 soon. Right now, I have the H&R springs, and the two front Tokico struts. I was planning on taking out the rear GR2's from my 96 and putting them on the 97 (returning the 96 back to stock), so I would have H&R's all around, Tokicos in front, and GR2's in back. I got confirmation from a few members that this would be good (even better than all 4 Tokicos). Anyways, has anyone ever actually done this? I am going for as smooth of a ride as possible. What are your experiences with this? I also want feedback from people with only H&R/Tokicos or H&R/GR2's. I hope this made sense... but please help me out... thanks!
I've tried the follow setups:
H&R/Tokico
H&R/AGX
H&R/Koni with the Motivational rear mounts.
I'm most happy with Koni's and Motivational Engineering mounts. On the downside:
Koni's are pretty pricey
Tokico HP rears don't control the ride enough
AGX's are too bouncy, sensitive to road imperfections, and adjustablitly is too narrow a range (you have pretty stiff to very stiff)
I suggest you use your GR-2's in the rear of your 97 if you're planning on returning your 96 to stock. If you do need new rear shocks, I'd suggest the Tokico Illuminas. They are adjustable and are great for just about every application...also Stillen has them for under $95, so you can probably get them for even less elsewhere. Be sure to get the ME Rear mounts...they are really really great.
H&R/Tokico
H&R/AGX
Also, whether I install the H&R/Tokico or the H&R/Tokico/GR2, how will the ride be compared to stock? Close? How about compared to Maxspeed/GR2's?
Thanx for your help!
Originally posted by djshawnee
What do you mean by this? How would the ride feel with all 4 Tokico HP's? Why is a firmer strut needen in back?
Well, the front Tokico's were fine with H&R spring. The rear however felt bouncier on the freeway and really didn't like going over railroad tracks. I guess, I felt that the rear flopped around too much on bumps. The AGX's, on the other hand, controlled the rear more (less bounce) but man...you'll feel much more bumps on the road. GR-2's are a little bit stiffer than stock shocks. Tokico HP's are softer than the GR-2's...so soft that people with Tokico/Eibach's complained after 10K miles, the rear's were already worn. But no matter what you do, get the Motivational Engineering rear mounts. From my experience, I wouldn't lower my Maxima without them.
Thanks a lot for your help thus far.
Originally posted by 95Max
The tokico seem to have too much compression damping and not enough rebound giving them a harsh but floatly feeling with stronger springs
Originally posted by njmaxseltd
H&R's coupled with Toks' up front and GR2's with the Motivational mounts in the rear will be a sweet setup.
motivational mounts go for around $125, don't they?
but what about without motivational mounts? i only have enough money to get either tokicos or gr2's in the back, unless i can get a really good deal.... so i have to choose between those two
MaxLvr21
10-17-2015 12:11 PM
Stagnet04
10-11-2015 08:16 PM
